Not sure which antenna you have but recently FR is using the antenna shown below on some of its units. They claim to be omni-directional, but are designed like a directional antenna. Unfortunately they do not perform well as either. Many people are replacing them with a King Jack antenna. Be aware that the King Jack requires a larger hole in the roof than the existing antenna ( currently only passed the cable) . This is a relatively simple DIY project with the exception of having to be careful not to damage any wiring or duct work when enlarging the hole. If you do not use the tv a lot another option is purchase an external HD tv antenna and mount on fiberglass painters pole outside the RV.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
