Old 10-26-2019, 05:51 PM   #1
Erinh's Avatar
TV (as in television)
Can I hook up multiple TVs to cable from the campground hook up? We have cable in the living room but itís raining so the kids want it in their room too!
Erinh is offline   Reply With Quote
Old 10-26-2019, 07:21 PM   #2
Retired JSO's Avatar
Using a splitter the cable can be split to more than one tv.
Retired JSO is offline   Reply With Quote
Old 10-26-2019, 11:14 PM   #3
bikendan's Avatar
Depends on how it's wired.
My TracerAir only provided cable on a single coax, to the living area tv.
I had to add a splitter to get the cable signal to the bedroom tv.
Equalizer WDH
Old 10-27-2019, 08:13 AM   #4
As bikendan mentioned, it depends.
Yes you can split a single coax feed into several separate feeds with a splitter and feed several televisions.
Whether YOUR R/V has that capability already built in is anyone's guess. They are all built/wired differently. Even same models.
Days Camped: '17=30 '18=51 '19=58 '20=55
Old 10-27-2019, 07:30 PM   #5
Be careful of splitter loss
Our Forester 2401R MBS has it split to the 3 TV locations. One thing to watch out for with splitters is the insertion loss, ideally -3 dB for a 2:1 split. Real splitters are closer to -3.5 dB loss (nothing is ideal). If the signal coming into your RV is weak already, that extra splitter loss could be really bad. Unfortunately on my Forester it is split in the internal wiring, i.e. I am stuck with it.
Anhkhong1 is offline   Reply With Quote
Old 10-27-2019, 08:22 PM   #6
Splitter Amplification?
Can the incoming signal be amplified during the splitting process to provide suitable gain staging and signal-to-noise ratio?
I'm new to RVing, but dimly recall using amplified splitters back when I had cable TV.
Paul Dershem is offline   Reply With Quote
Old 10-28-2019, 04:49 PM   #7
Cable amplifiers
There appear to be a good selection of cable amplifiers. Here is a snapshot I grabbed, but haven't done any research and make no claims regarding any of these products.
https://wiki.ezvid.com/best-cable-amplifiers
The amplifier needs to be bi-directional if you are using it for an internet connection. Some of these at first glance look promising. Keep in mind that your incoming signal needs to be relatively good. An amplifier can't fix a poor signal level or noisy input signal, it will just amplify the noise with the signal, i.e. signal to noise ratio doesn't improve.
