Have had similar issue with the sound bar which is in the slideout and shares the same circuit with Refrigerator ignitor and gas valve. Had issues with the ignition system and when it kept trying to light the sound bar would break up and put out static even when using USB's. Current draw was to high to run both. Making the assumption your TV is 12 volt and shares the circuit. Would like to separate the two, but running new wiring is a difficult task especially to the slide out.
2003 Duramax
2017 Crusader 315
2016 Boston Whaler Montauk 150
Former Montana owner
Colorado Cruiser, Over the Pass and Down the Hill
