Old 06-22-2024, 06:01 PM   #1
Tv lift
I have a 2022 Crusader 335RLP, the TV is on a lift that is operated by a up/down switch inside a cabinet. It went up and quit. I canít find any info on the lift itself and I need to get it down so I can go on vacation.i pulled a sticker off of the frame and googled the number I assumed is the model number, TV56-087. This is not useful either. I canít even find anything that resembles what I have. I am losing faith in Forest River and Rvís in general. Itís almost easier to glamp in a cabin. Almost. Iíve checked the fuses and GFIís. I do t have a way to the switch. Any advise would be appreciated.
Mycowmoos is offline   Reply With Quote
Old 06-22-2024, 06:30 PM   #2
This one https://elkhartrvparts.com/collections/tv-mounts-1
or
https://www.morryde.com/products/dro...unt-tv56-129h/
Larry
Larry-NC is online now   Reply With Quote
Old 06-22-2024, 07:21 PM   #3
check the up / down switch is working
you could swap the wires behind the switch so up becomes down
check the motor.. for loose wire
There should be access
Here is a install document for one of the TV lifts ... It may give you clues on what to look for ...
PLUS you may be able to remove the TV for travel untill you get it fixed
https://lci-support-doc.s3.amazonaws...cd-0002647.pdf
goodluck
Tarpon Springs FL
2022 Salem 24RLXL
Aussieguy is online now   Reply With Quote
lift
