Old 11-30-2020, 08:09 PM   #1
Uncled's Avatar
TV qUESTIONS
i HAVE A QUESTION ABOUT TV RECEPTION. I HAVE A ROKU TV IN MY TRAVEL TRAILER. WHEN I AM AT HOME IT WORKS ON MY WIFI. I HAVE A CABLE HOOK UP BY MY SOLAR POWER CONNECTION. I HAVE BEEN TO PARKS THAT SAY THEY HAVE CABLE AND GIVE CHANNELS. DO I NEED A CERTAIN RECIEVER BOX LIKE I USE AT HOME WITH UVERSE, CAN I GET A FIRE STICK OR ROKU STICK? I AM ALITTLE UN KNOWLEDGABLE ABOUT THIS 2ND YEAR AT CAMPING IN A RV. LAST PARK I STAYED AT I USED MY HOTSPOT ON MY PHONE TO WATCH HULU CHANNELS. ANY HELP WILL BE HELPFUL.... THANKS DAVIDB
Uncled
Retired Firefighter/Training Officer/Safety Officer
2020 ForestRiver Wildwood X-Lite 19DBL
2021 Nissan Titan
2017 Wife........
You dont stop playing cause you grow old, You grow old cause you stop playing
Uncled is offline   Reply With Quote
Old 11-30-2020, 08:23 PM   #2
bikendan's Avatar
Hi and Welcome to FRF, from a fellow retired firefighter.
By the way, using all caps in forum posts, is considered as shouting.
Can't answer your Roku question but we use our cellphones as hot spot for our Dish app and for the tv's Chromecast.
Some RV parks have cable channels available by simply scanning on the tv's cable setting. A few require a separate cable box.
Old 11-30-2020, 08:38 PM   #3
Hi,
I think you’re referring to two different things. The Roku is for streaming with WiFi or a hotspot. If the campground has cable, it is wired, not WiFi and you won’t use Roku with it. As bikendan mentioned, some require a cable box (I’ve only run into this once) and most don’t.
I hope this helps!
2018 F 150 Supercrew 6.5 bed 3.5 EB Max Tow
Jfkmk is offline   Reply With Quote
Old 11-30-2020, 09:37 PM   #4
All Around Hoser
Roku and Chromecast rely on an internet connection independent of cable and generally satellite, unless the satellite provider is supplying internet access. Your campground would have to provide internet access Aka wifi at speeds and connectivity that would allow streaming of your content choices.
Your cell service provider in most cases gives you internet access. You can "cast" YouTube and or YouTube TV to your flat-screen right from your phone. Likely your Roku too via the app - I don't have a Roku so might be off a tad on that one but would expect it to work the same as the others. Heck, let's throw in Amazon's Firestick. If you have a cell service activated iPad, you can do the same from it using the various apps.
Finally, you can turn your phone into a hot spot and create your own wifi and thus use your Roku by connecting it to said hot spot - or connect any of the other internet enabled devices.
--El Hefe
Baja Fog Experience Tour
2017 F-150 Lariat SC w/3.5L EcoBoost
Rockwood Mini Lite 2511S
BajaFog is offline   Reply With Quote
Old 11-30-2020, 10:25 PM   #5
Your Roku TV likely does not have a tuner in it. In order to use an antenna or the campgrounds cable you need an external tuner box like this one:
https://www.amazon.com/ViewTV-AT-300.../dp/B01MF9X5V9
NavyLCDR is offline   Reply With Quote
Old 11-30-2020, 10:37 PM   #6
Oops, I took this thread to
Mean Tow Vehicle
TV - 2020 RAM 3500 Mega Cab SRW with 6.7 Cummins HO & Aisin 6 spd, 4k payload, 23k towing
2002 GMC Yukon XL 2500, 8.1 liter (496ci), 4L85e & positraction with 3.73 gears
TT - 2013 Dutchmen Aspen Trail 3130 QBS
Great bourbon-just about any of San Diego’s craft beer
Beachbourbon is offline   Reply With Quote
Old 12-01-2020, 12:31 AM   #7
Mean Tow Vehicle
Just make sure if campground cable is connected to your TV to disconnect it before you drive off!
Old 12-03-2020, 06:16 PM   #8
Uncled's Avatar
Yes I know about upper case.
Uncled
2021 Nissan Titan
2017 Wife........
Old 12-03-2020, 06:22 PM   #9
Uncled's Avatar
I walk around before i pull off every time....lol thanks
Uncled
2021 Nissan Titan
2017 Wife........
questions
