Old 09-13-2021, 04:31 PM   #1
Smile Upgraded to Airxcel Colman Mach
Just and FYI to the forum.... On my Geo Pro 20 FBS I just upgraded the 13.5 BTU Coleman Mach AC unit ceiling unit and controls to the bluetooth system. I also added the heat strip option. As part of this upgrade I also tested the system on a 2200 watt duel fuel inverter generator (Pulsar brand). Everything works, both on propane and gas. No problem with the AC starting or the heat strip warming up. Honestly, I can't understand what is all the noise online about needing a soft start mod to run the AC off these small generators. Works fine for me.
gracieky is offline   Reply With Quote
Old 09-14-2021, 11:17 AM   #2
Retired Panpsychist
Theo's Avatar
Originally Posted by gracieky View Post
{snip}...Honestly, I can't understand what is all the noise online about needing a soft start mod to run the AC off these small generators. Works fine for me.
Well, I'm glad your genny and the 13.5 Coleman are a good match!
I think that most of the issues come from folks using a 15K A/C (or, sometimes a 13.5) with a genny that has a running watts rating <1,800. Some folks with these less powerful gennys find that the A/Cs initial start-up load is enough to trip the overload circuitry. In that case, the microprocessor-base soft start products "ramp-up" the initial start-up load in steps, preventing the overload protection from tripping.
An added benefit in doing this "soft" starting is lessening the start-up impact on the A/C hardware which, in time, may extend its life.
Theo & Carol
2007 GoldenDoodle ("Cooper") R.I.P.
2020 Rockwood Roo 23IKSS
2015 F-150 4WD XLT SCab, 5.0L, 3.73, 36gal, HD Towing Pkg (53A), 1,980lb Payload
Theo is offline   Reply With Quote
upgrade
