Vibe 313bh electrical, wth were they drinking
Removed the breaker panel to install the ems50hc. What a mess behind there, was able to straighten up some of their mess. Behind panel buried all the way back is the converter. It plugs 120v right into the back of the panel. To the right is another 12v fuse panel, so if you blew something and all main fuses r good you will have to remove the main panel and check those. Stupid setup to bury fuses, i would never have known. I installed the ems display right below the water/battery/black and grey display. What do i find behind there more fuses. Wtf, no rhyme or reason. At some point i will rip everything apart and make it right and accessible.
