Old 02-02-2024, 08:28 PM   #1
Want to replace my light switch with a dimmer switch
I have a 2018 Prime Time Crusader 28RL and want to replace my interior light switch and my awning light switch to dimmer switchers. The lights are just to bright and would like to tone done the LED lights. I have a double gang switch see photo provided. Has anyone done this successfully? What dimmer switch did you use.
Any help or guidance would be helpful
ID:	296744   Click image for larger version
ID:	296745   Click image for larger version
Dennis
Dennis78 is offline   Reply With Quote
Old 02-02-2024, 08:43 PM   #2
D W
D W's Avatar
It can be done IF the LED'S are dimmable. Some are not.
2016 Salem 27RKSS
D W is offline   Reply With Quote
Old 02-02-2024, 09:04 PM   #3
Thanks for the quick response. Is there any way to tell if they are dimmable?
Dennis
Old 02-02-2024, 09:40 PM   #4
Take the leads off of the switch and touch them to a 9 volt battery.
Home Depot has led dimmer switches but I think the LEDs have to be dimmable.
Capacitor is offline   Reply With Quote
Old 02-02-2024, 10:45 PM   #5
The quick and easy way to tame those LED lights is with something like LIGHTDIMS https://www.amazon.com/LIGHTDIMS-Dim...%2C116&sr=8-31
2015 Dynamax REV 24TB class C
Reverse_snowbird is online now   Reply With Quote
Old 02-03-2024, 06:11 AM   #6
Thanks I'll look into it.
Dennis
Old 02-03-2024, 07:02 AM   #7
Yes, I have successfully dimmed nearly all my motorhome and my trailer lights, including the awning strip. There are a lot of threads on the forum on this topic, including discussions of dimmer switches.
From my experience, all the 12 volt DC powered LED lights I’ve ever tried are dimmable. I have dimmers on 5 different types of RV LED lights, including the awning strip light. They all dim full range just fine. Nearly all LED lights in my motorhome are on dimmers.
I did use LightDims as mentioned earlier on the bedside reading lights, and to darken the display on the microwave oven. LightDims would obviously not be a good solution for an awning strip light.
Some 120 volt AC powered LED lights can be non-dimmable based on the type of internal power supply used. But, 120 volt lights are not generally what we’re talking about here in the RV. You should have no trouble dimming DC RV lights.
2020 Sunseeker 2440DS on 2019 Ford E-450, Trekker cap, Topaz paint
BehindBars is offline   Reply With Quote
Old 02-03-2024, 07:35 AM   #8
If there are two leads on the switch, they may very well be the +12 volt source, and the lead going to the light fixture. Connecting a 9 volt battery there would prove nothing and possibly cause damage.
The Home Depot does have LED dimmer switches, but are any of them for 12 volt DC circuits? You did not specify.
Have you encountered any specific RV DC lights that are not dimmable? If any exist, maybe we could compose a list.
Old 02-03-2024, 10:41 AM   #9
To the best of my knowledge, all 12-volt LED devices and bulbs are dimmable.
I've added a "dimmer control" to each fixture by adding a variable resistor in series with the 12-volt line mounted on the side of the fixture. The series resistance value is 500 ohms. This is for individual bulbs. As for the string of LEDs on the awning, a lower-value resistor will be needed as the current demand for the string is higher.
This was no "off the shelf" project but a DIY. With me being quite mechanically inclined and an electronic engineer, this was a "walk in the park" project. Your mileage will vary.
Bob
Bob K4TAX is offline   Reply With Quote
Old 02-03-2024, 11:00 AM   #10
yukongold's Avatar
. . . would like to tone done the LED lights. I have a double gang switch see photo provided. Has anyone done this successfully? What dimmer switch did you use.
Something like this? You would need two of them - one for each fixture you want to control.
https://www.recpro.com/rv-12v-dc-toggle-style-light-switch-with-high-side-dimmer/
this looks like the same switch for a couple of bucks cheaper:
https://www.amazon.com/RV-12V-DC-Incandescent-Lighting/dp/B0BZGMV41Y/ref=asc_df_B0BZGMV41Ytag=hyprod-20&linkCode=df0&hvadid=663236957902&hvpos=&hvnetw= g&hvrand=7922361337844134610&hvpone=&hvptwo=&hvq m
or, if you'd rather have a rotary switch instead of a toggle (but it has only a 5A rating):
https://www.amazon.com/dp/B0936W4T86...9kZXRhaWw&th=1
2007 Sierra 2500HD Duramax | ECSB
2012 Rockwood Minilite 2104 - Purchased 08/2012 - Sold 07/2022
2022 SOB 29' 5th wheel - purchased 09/2022; 400w solar on roof; 150w suitcase kit; 206ah LiFePO4; 2k inverter; boondock ready
yukongold is offline   Reply With Quote
Old 02-03-2024, 01:09 PM   #11
The first two dimmers linked are made by American Technology Components. They are very good 12 volt dimmers, that also come in a wider version with a larger dimmer slider. I have 6 of these in the large slider version. They all work great and have never failed. They do require that a ground wire be present at the switch location.
If the situation is such that a ground wire or point is not available at the dimmer location, there is at least one rotary knob dimmer that will work on just two wires. I have one of those, too.
Old 02-03-2024, 04:05 PM   #12
https://www.google.com/search?q=12+v...hrome&ie=UTF-8
Jim Moore
SW Colorado - 4-Corners Area
2020 Jayco X213 Rear Slide, 2006 RAM 1500 with Firestone Airbags No WDH
400 watts of solar on the roof & 200 watts of suitcase & 2 x GC2 batteries
Starlink Gen-3 running from a 500 watt pure sinewave inverter
Boondock almost exclusively on the shores of Lake Vallecito
jimmoore13 is offline   Reply With Quote
