Old 06-21-2024, 08:10 AM   #1
Kanadian Kamper
kenandterry's Avatar
Water accumulates on fridge floor
Our Dometic refrigerator is working fine considering the extreme heat and humidity we’re having in the North East of the continent, like a lot of people.
It’s been running on electricity and propane when dry camping. The freezer and refrigerator are still maintaining their respective inside temperatures according to our mini thermometers. Great news considering how often we’ve been opening the door and reaching for cold stuff.
We’re just noticing an unusual amount of water accumulation on the floor of the refrigerator itself. I’m guessing it’s normal given the extreme humidity and temps lately, and we just need to quickly remove stuff, and towel dry the excess, and carry on camping!
Comments?
Ken and Terry
2018 Sunseeker 2430S-CD, nicely modified and carried by a 2017 Ford E450 Sport with 6 speed Triton V-10
kenandterry is offline   Reply With Quote
Old 06-21-2024, 08:16 AM   #2
Do you have an icemaker that might be leaking?
Do you have a defrost tube that might be clogged?
If the answers are no, then I think your explanation is the correct one. Condensation is a problem in high heat and humidity.
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 06-21-2024, 08:18 AM   #3
Retired Georgia Rally
aceinspp's Avatar
Are you sure that the drain hose from the Freezer is attached. If it is defrosting some, water is suppose to drain through the hose to out side. Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
Old 06-21-2024, 08:22 AM   #4
I would be checking the door seals
and do you have kids? If yes get a recording or a sign
"Close the Blinking door"
Tarpon Springs FL
2022 Salem 24RLXL
Aussieguy is offline   Reply With Quote
Old 06-21-2024, 08:33 AM   #5
Check the drip tray below the fins in the fridg section and make sure it is pushed all the way against the back wall. Mine did that and the drip tray was about a half inch away from the back wall. Pushed it back in place and it fixed mine.
Also, assuming you are set up pretty level. If you are off level too much water from the fins might be accumulating away from the drip tray drain hole.
2016 Sunseeker 3010 DS
If dogs don't go to heaven, when I die I want to go where they went.
Will Rogers
Sunseeker16 is offline   Reply With Quote
Old 06-21-2024, 08:45 AM   #6
Kanadian Kamper
Replying to everyone here so far……
We have no ice maker.
The drain tube from the freezer is attached, has bug screen on and is dry.
The freezer back wall has ice build up……normal given our conditions.
No kids…..just adults that act like kids.
We’ll be home in a week, and after we unload, unplug the fridge, dry it out etc., I’ll closely inspect the door seals and clean them so they’re soft as possible to seal their best.
Thanks all. Carry on camping.
Ken and Terry
Old 06-21-2024, 09:04 AM   #7
Trailer Park Supervisor
NJKris's Avatar
I noticed that play in the condensate drip tray as well, you beat me to it. I run a dehumidifier in my trailer as long as I have shore power, I have to dump the tank everyday down South (30 pint unit).
Yes, I drink the water!
NJKris is offline   Reply With Quote
Old 06-22-2024, 07:51 AM   #8
Domer
We have the same issue with our refrigerator in our Mirada. Our solution is the same: remove the bottom drawer and soak up the excess water with a towel. A little annoying, but we've lived with it.
Domer1972 is offline   Reply With Quote
Old 06-22-2024, 08:38 AM   #9
Chuck_S's Avatar
This indicates to me the condensation from the fins that drips on the tray is not draining. On days with the humidity we're having right now I'd expect to see water drops at the end of the hose.
Got a circulating fan inside the refrig?
-- Chuck
Chuck_S is offline   Reply With Quote
Old 06-22-2024, 10:33 AM   #10
I put one of these fan units in mine a couple years ago. No more, or very little icing and the fridge cools much better. You can run 1,2 or all three fans and it has a light.
https://www.amazon.com/RV-Cooling-Un...9070184&sr=8-4
Will Rogers
floor, fridge, water
