Old 10-14-2019, 11:09 AM   #1
Water heater
I was winterizing my travel trailer and when I pulled my hot water tank plug there was no water but I was getting hot water through my faucets prior to that. I can’t figure out why there would be no water in the hot water tank.
Jwduffy is offline   Reply With Quote
Old 10-14-2019, 11:10 AM   #2
A32Deuce's Avatar
Did you open the low point drain first?
A32Deuce is offline   Reply With Quote
Old 10-14-2019, 11:14 AM   #3
Yes but not much drained from there either.
Old 10-14-2019, 11:32 AM   #4
The water heater will drain (not completely but mostly) by opening the low point drains, especially if you open a faucet to allow air in.
This is NOT recommended though as this procedure will often suck Calcium and debris from within the water heater, into the plumbing, where some of it remains and is then redistributed into the plumbing system on repressurization, thus, clogging toilet valves and faucet aerators.
Also make sure the water heater isn't simply vacuum air-locked. (water won't come out if air can't get in)
Open the T&P valve (temperature & pressure) to allow air in and see if more doesn't come out.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
heater, water, water heater
