Old 10-24-2019, 07:05 PM   #1
Water heater noise
My water heater makes a noise like itís expanding and contracting when the shower is first turned on, is this normal ?
CHEVY67TRK is offline   Reply With Quote
Old 10-24-2019, 09:06 PM   #2
Might be actually a water line connected to the heater that is moving slightly as the pressure is released when the shower is turned on.
Sometimes water heaters make various sounds when water starts to flow often a "gurgling" sound and sometimes just "creaking" if the insulation on the outside is foam and the tank is contracting a very small amount as pressure is released.
If no leaking, I'd write if off as "normal". In RV's we live a lot closer to our Water Heaters so it's not unusual to notice any noises they might make quicker than in a house where the heater is in the basement or garage.
"A wise man can change his mind. A fool never will."
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
TitanMike is offline   Reply With Quote
heater, noise, water, water heater
