Still in bypass from the fall?
Did you remember to take the water heater off Bypass? It was placed in bypass mode in the fall for winterizing, you know. If it is bypassed, there will be no pressure on it and it will remain empty--nothing from the anode rod/drain port or from the TP valve.
Larry
