My water heater switch stopped working (no toggle) so I opened up the panel and should have taken a picture of the wiring but didn't. I ordered a new switch and forgot the wiring pattern. It's only three post/clips but 6 connections are available. Any help with photo of your inside panel or ideas would help.
2015 Coachman Prism
See the attached photos.
I removed the switch and can't figure out the wiring pattern. 6 wire connections to 3 posts. I guess it's a standard wiring bundle when only 3 are needed. U
Check for 12v between the connector with the red wire and the black. If so, the black is used to light the switch. I would use those for the pos and neg to switch and a guess of one of the whites to water heater. Cross your fingers!
Thanks, worth a try. If anyone with a 2015-ish Prism 24G is willing to remove 4 screws and pull their panel out and ltake a picture, it would be awesome. Please PM me with the pic.
Thank you
I was looking for a Prism 24G in the San Diego area.
I was hoping remove the 4 screws to the panel, pull it out and photograph it. If not, I'll try to read the electrical schematic. Plan C is to use a wire between poles to see which lights the burner.
Thanks everyone for the support.
