Old 10-13-2019, 02:53 PM   #1
Water leaking from inside AC unit
Hi....hoping to find some answers. I have a Forest River Forester, 2019, 2251 SLE, that I took out on my second trip this weekend to Bahia Honda SP. There was a lot of rain during the night, with strong winds on and off. This AM, while the AC was working well, water came pouring out, onto the floor, maybe 1/2 cup or so. I turned the AC off, removed the filter, and dried off the area. I have since Googled, recommendations include tightening four bolts found in the corners of the unit or going up top and inspecting the roof unit....... Has anyone experienced this? Any other suggestions? Thanks
Nobo200 is offline   Reply With Quote
Old 10-13-2019, 03:10 PM   #2
SeaDog's Avatar
It may be the roof gasket leaking sometimes tightening the hold down bolts will fix that and going on the roof and taking the cover off and ensuring all the drains are open and not plugged especially from the indoor coil is important.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 10-13-2019, 03:13 PM   #3
Oldnapapartsguy's Avatar
What make and model AC?
Bill & Sue
Southwest Missouri, retired
2018 Dynamax Series 4
2014 Explorer & 2006 Jeep Unlimited
Oldnapapartsguy is offline   Reply With Quote
Old 10-13-2019, 03:20 PM   #4
I guess step one would be.... a roof inspection of the sealant around the AC unit.
They literally have a hole cut in the roof/ceiling, they set the AC unit down into that hole, and they apply dicor self-leveling sealant all the way around the perimeter after tightening the screws. You can change out an RV AC unit about as easily as you can change your oil in the car.....
If waters coming in, the first thing I would do is go up on the roof and make sure that the factory applied sealant was applied properly to actually maintain a seal. The next would be the condenser freezing/thawing. But start at the sealant, report back and you can be guided in deeper.
2017 Ram Rebel 1500 5.7L / 8 Speed, Max Tow 10,160 lb / 1,075 lb payload rating.
2019 F-150 King Ranch 3.5 Eco-Boost 10-speed, 12,800 lb / 1,546 payload.
2020 FR Coachmen Apex Ultra Lite 289TBSS
2019 Quality Trailers 16'x7' 7K GVWR Utility Trailer
2019 Iron Bull 22'x102" 14K GVWR Equipment Trailer
2019 Kawasaki Mule Pro DX W/EPS and Yanmar Diesel 2,000 LB towing and 1,000 payload.
Larry0071 is online now   Reply With Quote
Old 10-13-2019, 04:17 PM   #5
Not what I was expecting
So I was able to remove the cover from inside the rv.....and found what I suspect is mold! Very disappointed with this finding. I just picked up this rv @ 7 weeks ago, brand new, and have used it twice. Will contact dealer tomorrow.....
ID:	217207   Click image for larger version
ID:	217208   Click image for larger version
ID:	217209   Click image for larger version
ID:	217210   Click image for larger version
Old 10-30-2019, 01:09 PM   #6
I had the same problem. Bolts holding AC unit down vibrated loose. Tech retightened them and problem solved.
GLG311 is offline   Reply With Quote
Old 10-30-2019, 05:41 PM   #7
Ok, thanks for your response. I did have someone look up on the roof and they did not see anything grossly abnormal with the AC unit, etc. I did however tighten the 4 bolts inside, and some were noted to be lose. I hope this fixes the problem. Did your AC unit look like what appears to be mold or mildew? I applied hydrogen peroxide and gave it a slight scrub, without any improvement. I am waiting for the next rain storm and see how it does. Thanks again!
Old 10-30-2019, 05:47 PM   #8
No mold or mildew. It happened on a trip. Took it in for repair as soon as I got home.
Old 10-30-2019, 05:53 PM   #9
Ok. Thank you.
Old 11-01-2019, 07:11 AM   #10
Yep, has happened on every trailer we've owned.
Now when I get home with a new trailer it's one of the first things I do. Drop the inside cover and snug down the four bolts in the corners (not over tighten to the point of smashing the gasket).
2020 Rockwood Mini Lite 2109S
2017 GMC 2500HD Denali 6.6L
01tundra is offline   Reply With Quote
Old 11-03-2019, 02:35 PM   #11
Old 11-03-2019, 08:37 PM   #12
rk06382's Avatar
This is the same cover I had that Dometic replaced with an redesigned cover.
See thread: A/C leaking FR3
I sent this to Dometic RV PRODUCTS:
E-Mail: customersupportcenter@dometic.com
"I have a Forest River 2018 FR3 28DS with an Atwood/Dometic Air Conditioner that started dripping inside this summer. I read that you have replacement parts to fix this. (part numbers are 3315930.010 and 3317230.000)"
After an email asking for my model & serial number, They sent me a new redesigned cover with a better airflow.
New redesigned cover:
Robert
2018 FR3 28DS - Boondock 90% of the time
Samlex EVO-3012 Inverter/Charger | 600ah Battle Born LiFePO4 | Victron BMV-712 & MPPT 100/50 | 800W Renogy Solar | Fan-Tastic Fans | Blue Ox TruCenter | SnapPads | SumoSprings
Solar Power & Battle Born batteries
rk06382 is offline   Reply With Quote
Old 11-04-2019, 08:28 PM   #13
Thanks for info on this thread....this is exactly what I needed....I will be contacting Dometic tomorrow.....great thread and great info. Did you happen to have mold or mildew in the ac area.....on the sponge- like tan colored foam liner?
Old 11-04-2019, 08:37 PM   #14
rk06382's Avatar
No mold. I guess I was lucky.
Robert
Old 11-04-2019, 08:44 PM   #15
Glad to hear!
Old 02-04-2020, 11:27 PM   #16
Hi, I wanted to give a follow up on this issue I had posted a few months ago. I did contact Dometic, they immediately sent me the new, redesigned cover, with no questions asked. As others have mentioned, the instructions are not too clear, but the information posted on the thread mentioned above helped immensely. When I took off more of the AC unit, I saw much more mold. I cleaned the area, sprayed it with hydrogen peroxide (over several days) and went ahead and changed the parts that were sent from Dometic.
Since my RV is “new”, I contacted my dealer, sent in pictures and explained my situation. They immediately told me to bring it in, that they would fix it. Since I had reservations scheduled for Christmas, I was able to get the unit to them @2 weeks ago.
I was just notified that the unit will be repaired under warranty, that “the mold came from a water leak where the a/c mounting bolts go through from the roof”.
They are going to “remove a/c and replace foam seals and put new sealant down. Replace AC. Apply mold killing paint to boards around the AC to kill any remaining mold. 4.5 hours of labor, paint, foam strips and sealant.”
I am concerned that there could be more water damage throughout the unit. What steps should I take? Any suggestions will be appreciated. I am not sure if I should be doing more. Thanks
leak, water, water leak
