Old 06-11-2024, 07:30 AM   #1
Water Pump Pulsating
I have a 2018 Berkshire XL. I noticed the water pump pulsates. Is this normal? And when running on generator everytime it pulsates all the lights dim. Anyone else experience this?
GreeneTexas is offline   Reply With Quote
Old 06-11-2024, 09:19 AM   #2
A bypass valve, faucet, or low point drain left barely open will cause my water pump to run for a second, stop, then repeat. I'd call that pulsating. Are you leaking from any water lines or fittings?
ChrisParise is online now   Reply With Quote
Old 06-11-2024, 09:50 AM   #3
No leaks I’m aware of.
Old 06-11-2024, 09:56 AM   #4
Commercial Member
Pulsing means that the pump is sensing a demand and it short cycles. I would check all water lines for leaks and if those check out then I would check the actual water pump. It may have an internal leak in the diaphragm or a loose fitting and it is pulling air through the line somehow.
Lincman983 is offline   Reply With Quote
Old 06-11-2024, 10:12 AM   #5
Originally Posted by GreeneTexas View Post
No leaks Iím aware of.
Replace the pump. Try to buy it on Amazon where you can return it if the pulsating does not go away.
Old 06-11-2024, 11:07 AM   #6
I think we need clarification from the OP. Does it run when the faucets are all closed and there is no demand? Or does it pulse like every half second or so when a faucet is opened?
MGD1961 is offline   Reply With Quote
Old 06-11-2024, 11:53 AM   #7
Does not run with facets are closed. Only when open and pulsates and lights dim to the pulsation.
Yes , every second a pulsating.
Old 06-11-2024, 12:54 PM   #8
Mr. Dan's Avatar
As I remember, there is an adjustment on what I'd call a 'sensitivity switch' - it's a pressure sensor on the pump. Adjusted too sensitive, it calls for the pump to run too much. My technical terms should not be used in a court of law!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 =108/'21 = 115/'22 = 135/'23 = 78/'24 = 41; Booked for 2024 = 55
Old 06-11-2024, 01:30 PM   #9
Some really high end pumps have a differential setting to say it turns on at X psi and off at x psi. The difference is the differential setting. My bet is the op pump will only have an off adjustment if any at all.
This is pretty normal but the lights dimming is not. Could indicate loose connections or a weak battery
Easy way to fix the pump issue it to add an expansion tank like this.
https://www.westmarine.com/jabsco-0.67qt.-accumulator-tank-10286342.html?&utm_medium=cpc&utm_source=google&ut m_campaign=%5BADL%5D%5BPLA%5D%20Most%20Categories_ Test&utm_content=autoag0000x21019836630x10286342&g ad_source=1&gclid=CjwKCAjw65-zBhBkEiwAjrqRMG-cIN9_EnxD2fXvIYKFwaXRCIHuDaijo4ER5Z0QqV2tmU_GT_qx-xoCZZ8QAvD_BwE
Old 06-11-2024, 03:57 PM   #10
Trailer Park Supervisor
NJKris's Avatar
I quieted the 'drumming sound' by tucking bubble wrap between pump hoses and the cheap veneer style panels it was touching, thus making that pulsating sound. Helped a ton.
Yes, I drink the water!
NJKris is offline   Reply With Quote
Old 06-11-2024, 05:21 PM   #11
I don't own a Berkshire, but assuming they use a similar type water pump I think we need to understand why the lights are dimming. Pumps don't draw that much power. Even moving my slide in/out the lights barely dim. Sound like this pump is clogged up or the motor is toast.
Jim M.
2020 Flagstaff Super Lite 26RBWS
Former: 2017 Rockwood MiniLite 2104S
2015 Silverado 2500HD 6.0L Gas
jimmarako is online now   Reply With Quote
Old 06-11-2024, 06:34 PM   #12
Mr. Dan's Avatar
https://www.westmarine.com/jabsco-0....xoCZZ8QAvD_BwE
My pump is a low-end pump - Pentair Shurflo 4008 RV Revolution By-Pass pump. It has a hex head adjustment on the pressure switch. Here is a pic of troubleshooting instructions from my manual. Also, see post #8 from 2022.
Old 06-11-2024, 06:42 PM   #13
Thank you all so much. I will do some more checking later this week and report back and finding or solutions I find.
Again.. thank you all.
pump, water, water pump
