Originally Posted by RonHF
I recently purchased a used 2021 Geo Pro by Rockwood. I have two questions:
Welcome to the forum, Ron - this is a great place to learn, grow your skills and socialize with a bunch of us codgers!
1. how can I determine whether it has a 12v refrigerator or one of the other ones -- I cannot find a label on the refrigerator;
2021, the migration to 12v was in full swing. Do you have big metal fins inside your fridge? is there a switch that says anything related to "Gas/Electric/Auto"? If you said "YES" to EITHER of these questions, the answer is "you have a dual fuel/propane fridge." If you answered "NO" to BOTH questions (and your fridge looks, for the most part, just like a tiny home fridge), you have a 12v fridge. There are also RV's/trailers with full residential fridges. Likely, you don't have one of those in your Geo Pro.
I'mma hazard a guess yours is a 12v fridge
2. The on/off switch for the inverter does not seem to work. The on/off switch is under the table bench (the bench furthest to the back), and the inverter is under the bench. This is my first time to use the forum. Thanks.
The on/off switch for the inverter is actually ON the inverter itself. The switch you see (on the table bench) is the REMOTE switch. Take a look at your owners manual for your inverter to be sure, but - LIKELY the power switch on the inverter itself needs to be set to OFF, and the remote switch (the one you can see) needs to be set to ON in order for the inverter to provide 120v power to select outlets (which, by 2021, are usually marked as "powered by inverter" or whatnot). I know this doesn't make a lot of sense, but that's one inverter setup.
If you download the WE/RV app for your phone, and plug in your trailer type, it will bring up a relatively comprehensive set of manuals for your Geo Pro.
Just my .02, I could be (and likely am) wrong. Hope this helps.
