View Poll Results: In your opinion, which is the best RV Air Conditioner?
Dometic
18 |
35.29% |
Coleman
29 |
56.86% |
General Electric
2 |
3.92% |
Advent
0 |
0% |
Furrion
2 |
3.92% |
Atwood
0 |
0% |
07-30-2021, 08:13 PM
#21
Aren't Dometic & Atwood all one company now? Same with water heaters too??
https://www.dometic.com/en-us/outdoo...command-164502
2014 Prime Time Sanibel 3250
07-30-2021, 08:27 PM
#22
Commercial Member
Originally Posted by rracer5
Yes, but they are two completely different A/C's.
Dometic bought Atwood, but they did not own the A/C design (just right to mfg and sell). So they still sell it as is.
The Dometic A/C is designed by Dometic, is different design.
07-31-2021, 09:03 AM
#23
No mention of RecPro. Any opinions?
2003 Duramax
2017 Crusader 315
2016 Boston Whaler Montauk 150
Former Montana owner
Colorado Cruiser, Over the Pass and Down the Hill
07-31-2021, 09:57 AM
#24
Originally Posted by NJKris
heat pumps no good up here. My old unit is actually pretty efficient for 3.5 ton unit. I was told upgrading to newer 'high efficiency' unit, I would likely not recoupe extra cost of unit. My leccy bill is about 130/month, that is AC, basement dehumidifier, electric hot water and all electric appliances. Oh, and 400g hot tub.
your not saying sq ft of home and total electric home and mine has 80 hot water tank for my walk in tub. If you ask and contractor anything over 15 year olds isn't energy saver but burns more then new one's. Just saying
07-31-2021, 10:05 AM
#25
Our Dometic has been working just fine for nearly four years of hot Texas summers!
07-31-2021, 11:21 AM
#26
Hmmm...hadn't heard of RecPro. Do you have one?
2012 Cedar Creek 36CKTS Touring Edition
2015 Ford F-350 CC DRW Lariat
07-31-2021, 11:44 AM
#27
You are fortunate.
I went through 4 15k brisk air 2’s in 1.5 years.
This one has been functioning well for 5 years. However, it will freeze up when it is used during periods of 100% humidity and several days of heavy rain.
2017 Coachman Chaparral 336TSIK
2015 F350 6.7
07-31-2021, 01:58 PM
#28
07-31-2021, 04:20 PM
#29
Originally Posted by lesptr
You are fortunate.
look and pull you filter look at coil you should see 2 wires coming from it. some just have wires pushed into coil or round disk doing the same thing this keeps it from freezing check it out it may be a faulty.
07-31-2021, 07:02 PM
#30
Will do. Thanks.
2015 F350 6.7
08-05-2021, 06:09 PM
#31
None of the above
Please add "None of the above" to the bottom of your list so I can vote (and many others).
08-05-2021, 06:17 PM
#32
Trailer Park Supervisor
Somehow I missed this, sorry for delay. It's about 2300sq ft colonial, 8 ft ceilings. We keep it between 75 and 77 in summer, our bedroom I cool down to 70 at night using a window unit, we like it cooler for sleeping.
**and yes, all electric appliances and hot water. Woodstove and oil burner for heat in winter. I down sized from 80g water that was here when we moved in, o a 50g. It's just me and the old lady. We don't have that fancy natural gas. Wish we did.
Yes, I drink the water!
08-05-2021, 06:42 PM
#33
[QUOTE=NJKris;2607069]I was told to hang on to my 25-30 year old Lennox as long as possible, because the new ones just don't last. The outer cage is rusty and ugly, but it's still pumping cold air![/QUOT
There was a Coolerator (McGraw Edison) AC unit in the house we bought from my mother-in-law. It was installed in 1974 and was actually still running strong when we replaced it last year. It was undersized, that's the way they did it back then, so we decided it was time, since parts haven't been available for at least 20 years. I think almost 50 years old showed how they were built back then.
It sounded like a 747 taking off when it came on.
08-05-2021, 08:32 PM
#34
Coleman AC units
I have 2 Coleman Mach units, a 15000 and a 13500. The units and ducts were not installed very well though not particularly bad. I cleaned up the ductwork and did the modification that directs the air to the ducts much more effectively. My units are quieter and much more efficient! I just got the SoftStart for my 15000 unit but have not installed it. I want to be able to run at least 1 of the AC units on my 2300 generator if I need to cool mama or the pups in an emergency. I posted pix under the Shasta forum.
Phoenix 298RLS
2500 Ram Crew 4X4
DW & 3 pups
Ret LE 07/19
08-06-2021, 06:57 AM
#35
Originally Posted by Joe_GA
Hey guys. I'm looking for public opinion. There are 6 RV AC companies. In your opinion, which is the best? Dometic, Coleman, General Electric, Advent, Furrion and Attwood
I've had all three and I think they are all about the same. GE is a new comer to the RV Market.
08-08-2021, 09:32 AM
#36
Nope, I'm getting ready to install a unit in my fifth wheel bedroom, and need a low profile unit. RecPro came up in a search, and they seem to get good reviews. That's why I'm following this post.
https://www.recpro.com/rv-air-condit...ent=Appliances
2003 Duramax
2017 Crusader 315
08-08-2021, 10:32 AM
#37
Read a post on the Lance forum about a quieter AC from Recpro Houghton 9500 Btu quiet AC. The poster was impressed with the noise reduction. I know that's not what is being discussed but previously didn't know there was a quiet AC out there. Not cheap though.
https://www.recpro.com/rv-air-condit...5k-non-ducted/
2020 Rockwood 2104s towed by 2018 Nissan Armada. Curt WDH with sway, portable 150 watt solar, Home made window evaporative cooler
08-08-2021, 11:26 AM
#38
I ordered their 9.5 a few days ago, I don’t need the 13.5 unit I have so I giving it to our daughter since hers locked up and she has more cubic feet to cool than I have.
I hopefully won’t know about the durability for a while.
08-08-2021, 12:11 PM
#39
Electricity must be cheap or you have a very efficient home. The bill I just got was 225, but it has prolly averaged 95 or more as a high and someone is home ALL THE TIME! No set back for me.
Btw. No one cares, but I vote for Rheem or Ruud. I have put in a bunch of them and worked on bunches of types. I am not a huge fan of cleaning the older cube coils, but the rest was very easy to service. Overall for me…it’s the one I would buy.
2017 Puma 297RLSS
08-08-2021, 12:17 PM
#40
Thought the power use was high for a 9.5 compared to a 13.5 .
