Old 01-08-2023, 09:14 PM   #1
alsimmon11's Avatar
Wi-Fi
I am thinking about getting the Winegard GW-1000 Gateway 4G LTE WiFi Router. My Fifth wheel is pre wired with the 360 on the roof. Is this a good system and what Wi-Fi service do you use. I am not a full timer, but get out often.
alsimmon11 is offline   Reply With Quote
Old 01-08-2023, 10:22 PM   #2
bikendan's Avatar
Moved thread from the Modifications and Updates section to the Appliances and Electronics sub-forum since the OP is asking about Electronics.
Old 01-09-2023, 06:06 AM   #3
RickV's Avatar
Others may have had better luck but, I had issues with it and returned it. I was using it for LTE more than WiFi. It would need to be rebooted every few hours as it would just drop the signal and the signal was strong. I ended up buying a 8800l Verizon Jetpak and have had no problem.
2021 Alpine 3790FK
2021 F-350 SD XLT PS 6.7 Dually Longbed 4wd Crew Cab
RickV is offline   Reply With Quote
