Old 10-23-2021, 04:01 PM   #1
Wifi Ranger
I have a Flagstaff 26Fbs witha prewired wifiranger sky4. Anyone know how I can find the router. The antenna is off center on the roof so is cabled in the ceiling. There is a power switch for it on the main swich panel. Everything works like it's supposed to but I need a physical connection to the router.
Wiki is offline   Reply With Quote
Old 10-23-2021, 04:40 PM   #2
The whole thing is in that little unit on the roof, there is no option for an Ethernet connection.
2021 Coachmen Freedom Express 246RKS
2020 Ford Ranger
DougW is offline   Reply With Quote
Old 10-23-2021, 04:46 PM   #3
Just Tryin' to Help
cboss's Avatar
Turn it on. On your computer or tablet connect to the Ranger (I forget the IP address, but you can see it on your available Wifis. Then follow instructions.
Here's manual:
https://wifiranger.com/wp-content/up...nual_Rev11.pdf
WiFi Ranger IMHO is junk! Good Luck!
Craig & Cath
2017 Ford F250 Lariat, 6.2 gas (2022 F250 Lariat 7.3 gas with 10 speed Xmsn on order)
Equalizer Hitch w/ 4-Point Sway Control
Days camped since 2015(retirement): 1082
cboss is offline   Reply With Quote
Old 10-23-2021, 04:50 PM   #4
Thanks Doug. I was afraid that might be the case but all the product descriptions I could find seemed to indicate a separate modem. These is very disappointing.
Old 10-23-2021, 05:01 PM   #5
Thans Cboss. I have it working. I want to use my cell phone Hotspot as the wifi source but it only sort of works. I can get the ranger to connect to my phone as the source but it won't pull internet. I was hoping to maybe tether instead of Hotspot but I need access to the router.
Old 10-23-2021, 05:13 PM   #6
Just Tryin' to Help
cboss's Avatar
Just use the hotspot and forget the Ranger. We have been using our Jetpack or cell phones for years. The Ranger is not required.
Craig & Cath
Old 10-23-2021, 05:17 PM   #7
It's under the plastic radiome on the roof.
TT - 2021 Rockwood 2608BS
TV - 2020 F-250 XLT 4WD SRW 6.2L gas
mac1_131 is online now   Reply With Quote
Old 10-23-2021, 05:18 PM   #8
Separate modem is an LTE modem that plugs into the circuit board inside the antenna to give it 4G data capability. That might be what you were reading.
Old 10-23-2021, 05:22 PM   #9
The problem I was hoping to solve was my cell Hotspot only having a range of abt 5 ft. And I definitely don't want to add carrier capability to the ranger due to the cost.
Old 10-23-2021, 07:05 PM   #10
Hmm you could try connecting the wifi ranger to your Hotspot for its internet, then connect your devices to the wifi ranger. Since it's antenna is up on the roof, your devices should then work all over the place (half the campground).
wifi
