Old 10-28-2018, 11:24 PM   #1
Bayouownbeer's Avatar
Winegard Carryout G3 portable satalite
Will one of these domes hook up to the cable input and supply satalite signal to any TV in the coach just put the receiver on the corresponding tv?
2017 Georgetown 364TS
Bayouownbeer is offline   Reply With Quote
Old 11-09-2018, 09:04 PM   #2
Iím doubt it,I had three new units and always had to have a direct connection from satellite to receiver , just run it through your slide or have new connection installed
RVBill is offline   Reply With Quote
Old 11-09-2018, 10:08 PM   #3
Buy a small signal generator to trace the wires. I got one at Home Depot for around $15.00. Has saved me a lot of headaches.
2015 Chev Silverado 3500 dually D/A
2016 Cedar Creek 36CK
B&W Patriot 18K, Trail-Aire pinbox,
Level up, dual panes & all that stuff...
GOTTOYS is offline   Reply With Quote
Old 11-09-2018, 10:25 PM   #4
What I did: Plug G2 into sat/cable connector on RV. Connect sat/cable connector inside theRV to the G2 cpower insweter then the small cable from the inserter to the receiver. Your receiver should have an HDMI, composite and component outputs. I have the hdmi go to my living room tv. I have the composite go to a RCA to coax converter https://www.amazon.com/CIMPLE-CO-Com.../dp/B06XC9Y3VB
That coax tv output goes to a signal splitter. The signal splitter attaches to the coax cable that goes to my bedroom tv and one to the outside tv. When I select the receivers HDMI output, I get living room tv. When I select the receivers composite output, I get either the bedroom or outside tv (which is actually the tv from the bedroom moved outside).
flhtci2006 is offline   Reply With Quote
Old 11-11-2018, 08:53 AM   #5
I got a a person that installs tvís to trace mine down. Amish donít have a tv or electronics in there houses
spock123 is offline   Reply With Quote
Old 11-11-2018, 09:06 AM   #6
nomad297's Avatar
Some do and some donít. Theyíre not all as quaint as most tourists like to imagine.
Bruce
Old 11-11-2018, 09:06 AM   #7
Our 2019 Flagstaff has a cable connector and a satellite connector side by side.
ousooner is offline   Reply With Quote
Old 11-11-2018, 10:23 AM   #8
Thurman's Avatar
GOTTOYS: Please share info on the "signal generator", such as SKU#, you purchased. I did a "Home Depot" search and did not find this item. Thanks
2015 FR Freedom Express 310BHDS pushing a 2014 GMC Sierra CC
Thurman is offline   Reply With Quote
lite, winegard
