Originally Posted by SmittyCorp
Any opinions? My TT came with a Razar. I upgraded the power module with a SensarPro. The setup worked ok, but seeing as the antenna is low profile, and mounted directly in front of my AC unit, I always wondered if I'd be better off with a raisable batwing type.
Well, a big storm just blew through, and persuaded a tree branch to remove the Razar and smash it to bits on the driveway for me. Would it be a worthwhile effort to install a Sensar IV in its place? Or is the Razar a better antenna that I should simply replace?
I replaced my Razar with the crank up Winegard RVW-395 Sensar IV.
Used the same hole even though the orientation is backward according to Winegard Cust. Service. To orient it so it lays back along vehicle travel, according to them, will cause the wind while driving to rip the antenna off.
I went ahead and ignored their advice, orienting it so it lies down forward. Then checked to see if wind would be an issue by using my Leaf Blower that generates 110 mph wind speed. At least 7,000 miles on the road and no sign of any issues since then.
Only downside is you ABSOLUTELY HAVE TO LOWER the antenna before hitting the road. I had one close call and make sure to check before moving.
Oh yeah, reception is a quantum leap forward from the crappy performance of the Rayzar.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change
