07-08-2021, 08:15 AM
Gettysburg Pa to Williamsburg Va.
Need advice on route. I have a GT5 with a Jeep unlimited toad.
Is the best route 270 to I-95 then 64 to Williamsburg.
Any problems using this route other than traffic ?
Thanks for any advice.
Btm
Ben Moore
Temple,TX
2019 GT5 31L5F, 2014 Wrangler Unlimited
CHF rear, CHF front, Sumo springs front
07-08-2021, 08:21 AM
Insert witty title here
Other than traffic, which can be epic the route you describe will work just fine.
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2021 Chevy Silverado 2500HD LT 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
07-08-2021, 08:33 AM
Brake is on left
Beach traffic is really bad going in. Thursday and Friday are the worst. Plan around that if you can.
07-08-2021, 09:24 AM
As others suggest, that can quite enough!
Much depends on when you travel. These are my observations based on living in central VA and making dozens of work-related trips to Emmitsburg, MD (10 miles south of Gettysburg).
Highways around DC (270, 495, 95) are commuter routes and are among the worst on the East coast during weekday rush hour(s). Vacation traffic on 95 in the summer makes it worse. Your best bet might be to start out early on a weekend morning if you can. I usually find it smooth sailing driving home on Saturdays if I leave Emmitsburg at about 8 or 9 am. Problem with weekends going east from Richmond, though, is I64 (see below).
If I have to make the trip later in the day, or if Google Maps tells me I've got an hour-long delay somewhere along the way, then I'll often take US15 from Frederick MD (where normally I'd pick up 270) into VA, then to US17 at Warrenton, and from there to Fredericksburg where I get on 95. 95 south of Fredericksburg, though still busy, is usually much better than between there and DC. Under ideal driving conditions, 15 & 17 still add a considerable amount of time due to dozens of stoplights and reduced speed limits. But I'll take that over a classic I95 traffic jam.
Then there's I64 between Richmond and Williamsburg. As Evil Twin suggests, that's the main feeder route to the beaches of Virginia and the Outer Banks of North Carolina. I would add that weekends can be just as bad as Thursday and Friday. But to the Williamsburg area there is a decent backroad alternate: VA30, exiting off 95 a few miles north of Richmond. It's mostly two lanes but also mostly rural and relatively light traffic. You can totally avoid 64.
2021 Cherokee Wolf Pup 18RJBBL toy hauler
2023 Keystone Hideout 22MLS (got married, this worked better for the two of us than the Pup)
2021 Toyota Tundra
2006 Honda GL1800 Gold Wing (the reason for the toy hauler)
07-08-2021, 10:19 AM
Btm
If your concern is avoiding Washington I give you a partial answer based on how we come home to Ontario from FL up 95 eventually crossing at Buffalo NY .
You might consider a slight detour from Gettysburg to allow you to somehow get onto I81 S ( ( 30 to Chambersburg ?) Follow 81 down to I66 E , from I 66 take 17 down through Warrenton to Fredricksburg putting you on I95S
I guess from that point you could go as far as Richmond take 295 to 64 and follow it as far as Williamsburg
My 2 cents - good luck .
07-08-2021, 11:14 AM
That is a valid option, though it takes longer (assuming no traffic-related delays on either route) than US15. The OP might prefer it to avoid the lights and slowdowns on US15. US17 still has its share, though.
Then, to reiterate, I would avoid 64 by taking VA30 off 95.
2021 Toyota Tundra
07-08-2021, 06:04 PM
Take 15 south down to 17 south and pick up 95 down around fredericksburg. Take 95 to 295 to 64 from there. It is a much nicer ride and you miss all of tha dc trash but to each his own. Safe travels.
07-08-2021, 06:17 PM
Just did this today in the opposite direction and IMO...Jimbos route is the one to take. Dont forget to take I295 to bridge between i95 and i64. Avoid DC like the plague and take the Winchester, Warrenton, Fredericksburg scenic route!
________
Cam
2015 Georgetown 280DS
07-08-2021, 06:44 PM
No arguments from me, I was just not familiar with the part east of 95. I can validate your remarks about 64. I was in Williamsburg a few months ago and 64 east is certainly no prize when weekend beach traffic is on the move.
07-08-2021, 06:48 PM
Another route
Hello, when we drive south and want to bypass DC traffic, here is another route to look at.
Come down 695 from 15, take 695 to 97 towards Annapolis. Exit at 3 south to go towards Bowie, Then 301 south. Enter Virginia at Potomac River bridge. Stay on 301 out to 95. We try to travel this Early when all traffic is heading opposite direction. Minimum time on 95.
07-08-2021, 07:49 PM
Rts 15 and 17 would be my suggestion
07-08-2021, 09:22 PM
Richmond to Williamsburg
An option for you to avoid the possible I-64 parking lot from Richmond to Williamsburg is to take US Route 60 at Mile Marker / exit 205 as noted on the map link. Route 60 parallels I-64 and has none of the stress of idjits trying to race to Virginia Beach.
A bonus is that Route 60 takes you straight into Williamsburg.
https://bit.ly/3e0PFRb
I've used Route 60 for many years to bypass things traveling to and from Williamsburg from home plate here in Roanoke, VA when things went bad on 64.
Just a suggestion here, but the Virginia 511 App can assist.
Hope this helps
Chris in Roanoke, VA
2006 Sunseeker 3100SS/LTD
2008 Smart Passion Cabriolet TOAD
1986 Honda Helix (Original owner)
07-08-2021, 09:26 PM
You just need to go through early. If you roll through before noon you are fine in my experience.
07-08-2021, 10:09 PM
Travelled numerous times from Carlisle to Richmond with this route.
I give two thumbs up.... It might be a few more miles, but time wise will be about the same and a lot less stressful.
07-09-2021, 08:13 AM
Route Advice
Thanks for all the info.
I believe I will take the longer scenic route.
Gettysburg-Winchester-Warrenton-Fredericksburg-Richmond- and Hwy 60 Williamsburg.
Right now Google Maps show this route to be faster, because of traffic.
Thanks again
Btm
Ben Moore
Temple,TX
07-09-2021, 10:59 AM
AKA: 'tiredTeacher
Good choice. Access US60 from I-295, just east of Richmond.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
07-09-2021, 12:10 PM
Running back and forth Richmond to Gettysburg College shows no great routes. Wide detour to I81 (and then I64) reveals that road is vying for Most Trucks status. The pavement is worn to the point that while smooth the truck tramllines towing a travel trailer in certain sections.
The alternate routes sound better than the "straight shot." The Frederick-Fredericksburg "bypass" is no joy but it completely avoids DC. We're in Richmond and my daughter was just stick in traffic for "several hours" (probably 2 ) trying to get back from DC two weeks ago.
US60 Richmond to Williamsburg will work. We don't even take that to there but we're SW of Richmond -- and ain't lugging around a giant motorhome! -- we go VA10 an take the Ferry to W'burg.
-- Chuck
