11-14-2020, 07:38 PM
#61
Originally Posted by JohnAmi
We made it home! It went great. Even stopped for gas at a busy WAWA off the PA turnpike! Thank you for all your thoughts and prayers!!
Hooray, you’re a star! Enjoy your new TT
2020 Flagstaff 26FKBS
2020 Ram Tradesman 2500 6.4 Hemi
11-14-2020, 07:48 PM
#62
That's great news! Now you'll both be a lot more comfortable when you head out to have fun!
2019 Wolf Pup 16FQ - bought new 3/2020
2013 F150 5.0 STX SCab 4x4 SB/3.55 rear/tow pkg./36 gal. tank/1695 Payload/7350 GVWR
Andersen Hitch
11-14-2020, 07:53 PM
#63
Awesome! Good for you!
11-14-2020, 08:06 PM
#64
I don’t know how to post a pic. It says i need a URL or something ��
Open your recently received Welcome PM, click on the link to Forums 101, follow instructions in post 7 of that thread.
11-14-2020, 08:08 PM
#65
Have the dealer set up the hitch, while showing both of you how it's done, and how to unhook it. Make sure you do a proper PDI before accepting (signing for) the unit.
--2005 F350 Superduty Crewcab, 6.0, 4wd, short bed, 3.73 gears;
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
11-14-2020, 08:15 PM
#66
John and Ami
Pocono Mountains, Pa
2021 Rockwood 2507S
2019 Ram 1500 Rebel Crew
11-14-2020, 08:18 PM
#67
Very nice setup! Congratulations!
Andersen Hitch
11-14-2020, 08:36 PM
#68
Too late. They’ve already towed home today. See last few posts.
11-14-2020, 08:44 PM
#69
Hi,
I suggest making a check list of things to check before you put the truck in drive.
Safety-
Trailer Tires- proper pressure (should
Be a sticker on the camper)
Check tires for damage, lug nuts tight and no visible grease or problems with the wheels.
Truck tires check same thing. Door sticker should tell you proper pressure.
Hitch- Check for loose bolts, all fasteners are in place, adjusted correctly and safety chains are hooked.
Brakes- Get in truck and move forward a little then apply brakes by hand. The trailer should stop.
Brake away switch works?
Fluids check-engine, trans, radiator, brake fluid and next service is?.
Walk around- Doors locked, windows closed, nothing loose and so on.
So on and so on. Make sure you have a plan to change a flat tire.
Adjust all your mirrors so you just see a little bit of the trailer and learn your blind spots.
As said above drive at a comfortable speed. Make sure you are show. How to set up your weight distribution hitch correctly. I’m hoping they know how to do it. Good luck and have fun. It seems like a lot but really it’s not bad.
11-14-2020, 08:46 PM
#70
Oh wow I see you have it. Nice! How was your first pull?
11-14-2020, 09:02 PM
#71
Nice looking rig. You've obviously conquered not only towing but also backing up. Good job. Women can tow.
2015 Dynamax REV 24TB class C
11-14-2020, 09:04 PM
#72
Congratulations! Well done!
11-14-2020, 10:43 PM
#73
Just use an image hosting site. I use postimages.org
2019 Silverado LTZ 1500 6.2L 10 Speed 3.42 Max Trailering Package
2018 Freedom Express 192RBS
2022 Highland Ridge Open Air Lite Range 17BH
11-14-2020, 11:20 PM
#74
Use your mirrors to keep an eye on your trailer tires relative to the lane markings. It will take a little while before you have a natural sense of how close you are to vehicles in adjoining lanes.
I highly recommend an observation camera. FR puts a Furrion camera mount on the back that's prewired for power. Your dealer will be happy to sell you a Furrion camera at a pretty high markup but that also means it will be installed before you leave the lot.
They're also available on Amazon and easy to install (a couple of screws) if you have a ladder to reach it. If you get one, compare the Amazon price to your dealer price before you decide.
Measure the height of the front fender opening before you leave home. That will rise when you connect the trailer because the rear of the truck will squat. When the springs are engaged on the weight distributing hitch, the rear will lift up some and the front fender will come back down.
Your truck's towing guide will tell you how much it should return to normal when correctly hitched. If it doesn't return to the towing guide height, have the dealer adjust the hitch to meet the specs.
TV: 2021 Ford F-150 4WD XLT Crew w/ 3.5L EB & HDPP, payload: 2,416#.
Camping nights: 2021, 52; 2022, 99; 2023, 88; 2024, TBD (Est: 80+)
11-14-2020, 11:28 PM
#75
Wow, read the thread. They are already home and all is well......
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
11-14-2020, 11:32 PM
#76
So I saw. No reason to change what I wrote. Sorry you're aggravated.
11-14-2020, 11:35 PM
#77
They already figured it out in post #66, 3 hours ago.
11-14-2020, 11:48 PM
#78
Congrats! You are now an experienced tow'er!!!!! Just gotta take it "low and slow" like cooking ribs! That is one sweet looking setup you two have. Enjoy and stay healthy!
2021 Wildwood X-Lite 233RBXL
2016 Dodge Ram 1500 Laramie Longhorn
(Yes, it is big enough to tow safely)
11-14-2020, 11:54 PM
#79
Well you have received plenty of advice, most of it good. Just pick a time with minimum traffic, go slow, enjoy the new experience.
2021 2205S Rockwood Minilite
2019 F 150 Lariat 3.5 Eco Fx4 Max Tow
Equal-i-zer WDH, 1809 lb payload
11-15-2020, 06:53 AM
#80
I absolutely love this. You have just empowered me. You should be an inspirational speaker. Thank you!
Towanda!
