01-24-2020, 05:07 PM
#21
If you don't plan to leave the insert in with the hitch pin, I recommend you add a note or marking on the hitch to remind you to remove the insert so it doesn't fall out while driving without the hitch.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
01-24-2020, 05:08 PM
#22
It will rust in there soon enough, then it won't fall out......
01-24-2020, 06:14 PM
#23
Originally Posted by Bluemoose
Travel Trailer is Rockwood Mini Lite 25', so not all that heavy. Of course I still use a WDH. I was towing with 2015 Tahoe, but recently purchased a GMC 2500 which has a 2.5" hitch.
Am I ok using the 2" adapter (insert sleeve) that came with my new truck?
If I were towing 10 or 12K lbs, I'd likely buy a new hitch in the 2.5" size, but that seems like overkill for this smaller TT I'm towing.
Opinions?
I have one question for you..............
Do you imagine that the auto maker would provide the adapter if it were unsafe or limited the use of the hitch in some manner without making a limitation as such in the Owner's Manual.
That would open them up to HUGE lawsuits and probably put them into permanent Bankruptcy, from which they would NEVER emerge, should it be found it was unsafe.
All the sarcasm aside, it will be FINE!
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
01-24-2020, 06:20 PM
#24
I used the sleeve in two different 2500 GM trucks for 8 years or so pulling up to 7000 pound trailers. Wrap the sleeve with a few rounds of Gorilla tape, cuts down rattle. Just replace the tape ever so often. Always replaced the locking pin in the receiver to keep sleeve secured and to know where locking pin was when I needed it next hookup.
2020 Georgetown 31L, Safe T steering, Sumo springs, Onan Geny
2015 GMC Canyon 4X4 TOAD w/Blue Ox tow plates, InvisiBrake
Pepper 🌶 PomChi rescue 545 nights as our camping buddy
Days camped in FR 2011-12 = 77, 13-14 = 98, 15-16 = 129
17 = 81, 18 = 44, 19 = 83, 20= 45, 21 = 76, 22 = 57, 23 = 42
Retired :
01-24-2020, 07:04 PM
#25
Been using the 2" adapter on my 2018 Ram 2500 for the last 5000 miles of towing a 9500 lb TT that has a 1350 lb TW. Zero issues. I use one of those locking hitch pins and it stays in the hole 24/7 so my adapter's always where I need it.
01-24-2020, 08:46 PM
#26
Grammar Pedant
Originally Posted by Joe_GA
Didn't Ford give you the sleeve? My 2015 came with one and a pin.
Nope. Ford stopped doing that for 2.5 in 2019. It still gives a 3 to 2.5 reducer for those configs that have a 3” receiver, I believe. But nobody gets the 2.5 to 2 reducer anymore.
Former RV: 2018 Rockwood Mini Lite 2504S
01-24-2020, 11:32 PM
#27
Shame on Ford. A lousy 10 bucks. SMH
2012 Cedar Creek 36CKTS Touring Edition
2015 Ford F-350 CC DRW Lariat
01-25-2020, 01:47 AM
#28
Originally Posted by Ejs4029
For what's worth I ditched the sleeve and went with a 2.5" shank...No slop, No rattling 100% Happy
Is this pic at Carabelle? Looks like the same spot LOL
01-25-2020, 07:07 AM
#29
I went with a B&W sleeve. Plus had to buy a longer pin.
TV:2019 F350 6.7L Diesel
RV: 2018 Coachmen Apex 249RBS
01-25-2020, 09:30 AM
#30
Pulled my 10K trailer with the Chevy provided sleeve for 3 years and about 15K miles. No problems, rattles, or rusting in place. Always in, with a locking pin. Just bought a RAM, have the factory sleeve in, locking pin in, will be towing in a month or so with it, no worries.
Neither owners manual have any additional weight restrictions when using the adapter sleeve.
01-25-2020, 12:28 PM
#31
My 2016 GMC Denali Duramax came with a sleeve and I was using it with an Equalizer to tow my 8329SS but having issues. A couple folks on here suggested that some of my issues could be related to the slop in the adaptor sleeve. So when I decided to move to the Blue Ox SwayPro with 1,500 lb bars, I contacted Blue Ox and they sent me a 2 1/2" shank for free. I just had to send them back the 2"' shank. Great company and great hitch. The SwayPro with the 1,500 lb bars and the 2 1/2" shank made a huge difference in pulling the trailer. Much more stable and no sway. Now that I've moved to a 5th wheel though it's time to sell the hitch.
2020.5 Cedar Creek Hathaway 34IK
2023 GMC SierraHD Denali Ultimate 4WD DURAMAX
Bosco the Golden Doodle
#32
I have been using the adapter since 2016 with a tongue weight of 1350 lbs. towing a 10,0000+ Puma, no problem.
01-25-2020, 05:15 PM
#33
I have a 2019 Ram 2500 w/2-1/2" hitch. I bought an adapter from Mopar which works great! I would highly recommend to buy an adapter that has been 'notched' on both sides so your holes line up; otherwise, it is a pain trying to line up 2 sets of holes for the pin.
01-25-2020, 05:48 PM
#34
Opinions?
The factory one fits much better then the after market ones . at first i bought a curt adapter and lining up the holes was a pain and it was loose in the 2.5 receiver . took it back to wal mart not worth $2 let alone $13 . the factory GM reducer fits like a glove the holes line up perfectly when installed and no slop .
01-27-2020, 08:02 AM
#35
Originally Posted by UGACamper
Yeah it was at Carabelle...Site #48
2015 Ram 2500 CTD,CC,SB,4x4
2016 Rockwood 2703 Emerald Edition
Husky CenterLine TS Hitch
TST 507 TPMS
Progressive Industries EMS-PT30X
01-27-2020, 10:43 AM
#36
Ford 3" to 21/2" Adapter
Ford does not include it on the 19' Super Duty F-350. Not $10, but $45. Rip, I had mine 3" tack welded to a 2 1/2" adapter for all trailers. Trying to line up all 2 adapters and WDH is a PITA. Easy to pinch fingers. Also bought a 3" to 2" adapter and can open my tailgate, $75. I use this w/ utility trailers. W/ my TT, it causes it to tow worse. I have a nose heavy trailer and w/o switching head and bars to go to next heavier bars, better w/ the original set-up. This is only drawback I have found w/ Equalizer hitches. Going from 10K to 12K, you have to change head and bars. I believe it is the same w/ lighter.
01-27-2020, 10:57 AM
#37
Grammar Pedant
Originally Posted by Tundra 2014
Ford does not include it on the 19' Super Duty F-350. Not $10, but $45. [...]
You need to find a better dealership, if they're quoting you $45 for the 2.5 to 2.0 reducer. That's PN HC3Z-19H282-A. It's $20-$25.
The earlier post was talking about Ford. It's a rotten deal by Ford to omit this part because Ford is only saving about $10. If the part retails for ~$25, then, yeah, Ford's cost of that part is probably $10 or less. So, it passed along an inconvenience to the customers like me to save $10 on the build. Bad decision. Penny wise, pound foolish.
I agree that if you were removing and installing the sleeve all the time, it would be a big PITA. For me, I put my hitch in at the beginning of camping season and leave it there until we're done. The cheap-o Curt/Reese sleeve I got at Walmart for $10 works well. Yes, I have to take care to line up the holes. But, it's snug and stable.
My assumption is that the Ford sleeve fits better and auto-aligns the holes. I haven't ever tried one, though.
01-27-2020, 08:30 PM
#38
Adapter
It was the 2.5" to 3" adapter that was $45. I checked w/ another dealership later, same price. I agree w/ finding another dealership, but for different reasons. Sad that on a $70K truck the 2.5" to 3" adapter is not included. Also sorry that they dropped the Rancho stocks off the FX4 package w/o reducing the price. Going from Toyota to Ford, service has been disappointing so far. I have been waiting for a part for 6 months under warranty. No call backs, ETC.
01-27-2020, 08:50 PM
#39
A black sleeve in a black receiver becomes invisible. Unless you install it so it can't come out, paint the end white or orange, because one of these days, you'll remove the shank and forget the sleeve and it will drop out later on when you drive down the road.
Don't ask me how I know.
2011 Traverse LT, 3.6L, FWD
01-27-2020, 09:33 PM
#40
Grammar Pedant
Sorry to hear about the service, but it might get even more frustrating for you ...
Fords that have the HD 3” receiver hitch still come with the 3” to 2.5” reducer. I may have mentioned that above, but can’t be bothered to check. Either way, those are still meant to be included.
It’s only the 2.5” to 2” reducer that is no longer included. If you have a 3” receiver, then the Ford uses a cascading system. It’s the same base PN as I listed above with the suffixes for light duty hitch 2.5 to 2 (A), HD hitch 3 to 2.5 (B), and HD hitch 2.5 to 2 (C).
This link explains it a bit more.
I’ve also seen one-piece 3” to 2” reducers in the aftermarket.
