Old 01-24-2020, 09:34 AM   #1
2.5" to 2" adapter
Travel Trailer is Rockwood Mini Lite 25', so not all that heavy. Of course I still use a WDH. I was towing with 2015 Tahoe, but recently purchased a GMC 2500 which has a 2.5" hitch.
Am I ok using the 2" adapter (insert sleeve) that came with my new truck?
If I were towing 10 or 12K lbs, I'd likely buy a new hitch in the 2.5" size, but that seems like overkill for this smaller TT I'm towing.
Opinions?
Bluemoose is offline   Reply With Quote
Old 01-24-2020, 09:37 AM   #2
You should be fine with the adapter insert.
2020 Coachmen Mirada Select 37RB
2019 Ford Mustang
H&H Aluminum Car Hauler
Cricket RX5 Golf(?) cart
DougW is offline   Reply With Quote
Old 01-24-2020, 09:42 AM   #3
007matman's Avatar
You'll be fine.
007matman is offline   Reply With Quote
Old 01-24-2020, 09:45 AM   #4
Hatchdog's Avatar
I used one for years pulling a 6500 lb trailer. Worked fine.
2020 Rockwood Ultra-lite 2608BS TT
2011 F250 Lariat 6.2 gas 6 sp auto 3.73 rear 4X4 6.75 bed crew cab
Recurve R6 hitch
Hatchdog is offline   Reply With Quote
Old 01-24-2020, 09:58 AM   #5
You may find this interesting - https://www.etrailer.com/question-151257.html
Skip12 is offline   Reply With Quote
Old 01-24-2020, 10:00 AM   #6
I'm using a sleeve on mine, no problem. I would grease the sleeve though, I have heard of the sleeve rusting inside the receiver.
2018 Ram 2500 Tradesman, CTD/CC/SB/4X4/Equalizer WDH
2019 Forest River Surveyor Legend 19BHLE
upflying is offline   Reply With Quote
Old 01-24-2020, 10:01 AM   #7
Mr. Dan's Avatar
So the applicable info in that link is this:
A hitch reducer sleeve such as Reese Titan Reducer Sleeve # 58102, which fits into a 2-1/2-inch hitch to reduce it's receiver opening to a 2-inch size, is the only type of adapter that does NOT cause a loss of hitch capacity because it does not alter the distance/geometry of the hitch tube.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 86; booked = 39
Old 01-24-2020, 10:21 AM   #8
Grammar Pedant
67L48's Avatar
My truck also has the 2.5" receiver. I grabbed a Curt or Reese sleeve at Walmart for $10. Works great.
RV: 2018 Rockwood Mini Lite 2504S
67L48 is offline   Reply With Quote
Old 01-24-2020, 01:05 PM   #9
Pulled a 10K tt with no issues, before that a 7K tt with no issues.
Ron and Kathy
2019 Cougar 369BHS 5'VR
2018 Cherokee Limited 304 BH (Traded)
Joyfully Towed with a 2018 RAM 3500 6.7 G56
ronheater70 is offline   Reply With Quote
Old 01-24-2020, 01:11 PM   #10
The GM hitch adapter is much nicer. This link has the GM number, if you wish to shop around.
Genuine GM 15923277 Trailer Hitch Draw Bar Adapter https://www.amazon.com/dp/B00F675AWU..._hDdqr1Iyyqn6c
Edit:. Make sure to have a longer hitch pin, too...
aeblank is offline   Reply With Quote
Old 01-24-2020, 01:47 PM   #11
Dave Lyon's Avatar
Yep.....that's what it's for. I've had no trouble - it works well.
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
Dave Lyon is online now   Reply With Quote
Old 01-24-2020, 01:52 PM   #12
It should work fine but I've found it introduces a bit of looseness that i found annoying.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
CedarCreekWoody is offline   Reply With Quote
Old 01-24-2020, 01:54 PM   #13
PINTO
Kpinto's Avatar
Sleeve
Don't forget to remove the sleeve when you remove the hitch. Ask me how I know. I work in the metal industry so I got a piece of 2" Square tubing and cut it to length. Home made sleeve.
PINTO
2011 Fuzion 325
2015 Duramax Diesel
Chevy 3500 LT Dually
Kpinto is offline   Reply With Quote
Old 01-24-2020, 02:12 PM   #14
Didn't Ford give you the sleeve? My 2015 came with one and a pin.
2012 CC 36CKTS Touring Edition
2015 Ford F-350 CC DRW Lariat
Joe_GA is offline   Reply With Quote
Old 01-24-2020, 02:28 PM   #15
Ejs4029's Avatar
For what's worth I ditched the sleeve and went with a 2.5" shank...No slop, No rattling 100% Happy
2015 Ram 2500 CTD,CC,SB,4x4
2016 Rockwood 2703 Emerald Edition
Husky CenterLine TS Hitch
TST 507 TPMS
Progressive Industries EMS-PT30C
Ejs4029 is offline   Reply With Quote
Old 01-24-2020, 02:30 PM   #16
llr
I plan on switching to a 2.5" shank for the TT do to the holes in the adapter flaring and making it hard to remove and the additional play. I will keep using the adapter for the utility trailer.
My TT is heavier so no idea if you will have any issues, try it and see.
TT 2017 Flagstaff 831CLBSS Classic Ultra lite
TV 2014 Silverado 2500 HD
llr is offline   Reply With Quote
Old 01-24-2020, 02:32 PM   #17
I bought materials to make an extension. Long enough?
https://i.imgur.com/i9Z6pLi.jpg?2
I did actually buy materials to extend and enlarge the hitch, but probably only go a couple inches. I want to be able to open my tailgate. The materials were cutoffs and cutting would be more expensive than the material.
Old 01-24-2020, 03:33 PM   #18
That would be my choice as well.
Andersen hitch
Old 01-24-2020, 04:01 PM   #19
Tundra 2014
Adaptor
Good to go.
Tundra 2014 is offline   Reply With Quote
Old 01-24-2020, 04:59 PM   #20
If you are using the same pin hole , regardless of what type sleeve is used how does that change the geometry?
AdamKam is offline   Reply With Quote
