Old 04-15-2024, 08:09 AM   #1
20" wheels for towing?
I'm shopping for a new TV. Likely a 3/4 ton. Chevy's "Custom" trim comes equipped with 20" wheels only.
Are 20" wheels okay for towing mid-size travel trailers? Does the tire size make a difference? ... would appreciate your thoughts and comments. I'm not concerned about MPG, and there won't be any off-road driving.
I'm an old-fashioned thinker and would opt for 17" rims. Maybe I've fallen behind the times - again.
2023 Winnebago Micro Minnie 2108TB
2017 Toyota Tundra
Sunspot is offline   Reply With Quote
Old 04-15-2024, 08:30 AM   #2
If the 20" wheels are a factory option, not aftermarket installed by a dealer, then the towing specs for that vehicle are as stated by mfr. Match the specs, not wheel size, to your trailer
17" wheels could limit your future tire replacement options as the popular wheel sizes today are 18"-20". Larger wheels allow mfr's to use larger diameter brake rotors.
As for falling behind the times, that's easy to do today. I just replaced an older tow vehicle that had a 5.6L, 300hp V-8 and ~400 lb/ft torque with a 3.5L V-6, 400hp and 500 lb/ft torque. Back in the day that performance was only possible with big block V-8's or diesels.
Old 04-15-2024, 08:37 AM   #3
Make sure the bigger rims don’t have a lower profile tire
I like lots of rubber between potholes and the rim
Tarpon Springs FL
2022 Salem 24RLXL
Aussieguy is offline   Reply With Quote
Old 04-15-2024, 08:44 AM   #4
It may not matter much on a 3/4 ton but on a 150 / 1500 class truck, 20" wheels eat into payload and on modern trucks, especially the higher trims, almost all the time, you'll be up against payload limits, before published towing limits.
2024 Surveyor 252RBLE
2023 F150 Powerboost 7.2KW 4x4 1658PL with a WeighSafe WDH
DJ252 is online now   Reply With Quote
Old 04-15-2024, 09:55 AM   #5
Jim34RL's Avatar
Also make sure the 20" tires are LT (light truck) and not P (passenger) rated tires. As P rated tires do not have the load capacity of an LT tire.
I myself would recommend the 18" tires since you can get a lot of LT tires in that size class from many different tire manufactures to suit your needs.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
Old 04-15-2024, 10:43 AM   #6
my 2019 chevy 2500 started with 17" went to 18" and wish now i went to 20" still plenty of rubber for those off road excursions . handling is better with the larger rims . for towing i don't think it matters as long as you have a LT tire .
MR.M is offline   Reply With Quote
Old 04-15-2024, 10:48 AM   #7
Rhumblefish's Avatar
Originally Posted by Aussieguy View Post
Make sure the bigger rims donít have a lower profile tire
The bigger rim will *absolutely* have a lower profile tire in order to keep the outer diameter of the tire the same (which, in turn, keeps the gearing, the speedometer and the odometer all the same, etc etc).
Like you, I like a lot of rubber between potholes and the rims, but you're not getting more rubber unless you're (1) going to smaller diameter wheels, or (2) moving to larger outer diameter tires (which can have all kinds of unintended consequence).
That's math staring back at you!
2022 Rockwood Roo 235S
15kBTU AC; 12v fridge; 1kW roof-mounted solar panels; 80 amp MPPT charge controller; 3,500w pure sine wave inverter; 30a automatic transfer switch; MicroAir EasyStart, 600ah Chins LiFePo; Honda EU2200i (with Hutch Mountain propane conversion kit) gathering dust in the storage unit.
Rhumblefish is offline   Reply With Quote
Old 04-15-2024, 11:02 AM   #8
My 2016 Silverado 1500 came with factory 20" P-Metric tires while my 2019 Silverado 1500 came with factory 18" P-Metric tires. Quite frankly, I couldn't tell the difference in ride quality between the two. Nor did I have any issues towing with P-Metric tires at the factory recommended 35 psi. Going with a 3/4 ton means you'll be getting LT tires, not P-Metric. But I don't imagine there will much of a difference between 18" and 20" there either.
2019 Silverado LTZ 1500 6.2L 10 Speed 3.42 Max Trailering Package
2018 Freedom Express 192RBS
AlaskaErik is offline   Reply With Quote
Old 04-15-2024, 11:07 AM   #9
Our 2011 Chev Silverado Crew Cab LTZ with factory tow package does have 20" tires. I replaced the original ones with Michelin LTX MS2 tires. No issues of concern and we love the ride.
Yes, with this truck we do hit max payload before max towing limits. We just have to be careful how and where things are loaded.
Bob
Bob K4TAX is offline   Reply With Quote
Old 04-15-2024, 11:19 AM   #10
Ejs4029's Avatar
My 2015 Ram 2500 has the factory optional 20" wheels tire size 285/60/20. I prefer the look of the large wheel and tire combo.
2015 Ram 2500 CTD,CC,SB,4x4
2016 Rockwood 2703 Emerald Edition
Husky CenterLine TS Hitch
TST 507 TPMS
Progressive Industries EMS-PT30X
Ejs4029 is offline   Reply With Quote
Old 04-15-2024, 11:22 AM   #11
MillMitch's Avatar
true, but I was always under the impression that the larger aluminum rims were primarily to reduce weight? Unrelated, but this string reminded me. I had a late 90's Chevy 1500 w/ 15" tires, which looked puny in the wheel well. Replaced the rubber with 30.5x10.5x15's, which filled the wheel well much better and yes, it threw off the spedo and odometer
Mitch in MN
2018 Patriot (Grey Wolf) 23MK travel trailer
2011 Durango 5.7L and OEM tow package
MillMitch is offline   Reply With Quote
Old 04-15-2024, 11:23 AM   #12
Most trucks now days can be programed for the larger wheels and tires . chevys come with std 17" you can get 18" or 20" and both come with larger dia tires that the dealer can reprogram the truck to correct speedo error . When i went to the stock 18" mag wheels from a take off of a higher trim level chevy the tires were almost 2" taller but the dealer was able to correct . not the day of a speedo cable anymore
Old 04-15-2024, 12:49 PM   #13
In 2019, Ford REQUIRED 20” wheels for the Heavy Duty Payload Package.
Also, FORSCAN (the Ford Engine/vehicle program) can easily switch to any factory size tire/transmisson/rear axle to keep the speedometer accurate.
2019 Cherokee Wolf Pup 16BHS flipped axle, 5K springs, 400AH LiFePO4, 3K inverter, 400 watts CIGS solar
2019 Ford F-150 S-Crew 5.5 bed V8 w/tow package, ITBC, Tow Mirrors, SumoSprings, 1990#CC
Husky Centerline TS WDH 400-600# spring bars
Boomerweps is offline   Reply With Quote
Old 04-15-2024, 01:55 PM   #14
And everybody got power steering
Wheel size and weight not such a big effort anymore
Now when I was a kid learning to drive power anything including a heater was a luxury
Tarpon Springs FL
2022 Salem 24RLXL
Old 04-15-2024, 03:38 PM   #15
I guess I didn't take into consideration reprogramming for wheel and tire combos, especially as being so prolific in the truck world. Thanks for setting me straight, fellers!
Old 04-15-2024, 03:56 PM   #16
as mentioned above in Ford's case the largest towing weights required 20" wheels.
2019 F150 4X4 7050 GVWR 1903 payload
2018 Avenger 21RBS 7700 GVWR
Mike134 is offline   Reply With Quote
Old 04-15-2024, 04:12 PM   #17
Lower profile tires will have less sidewall flex which will help with steering and stability when towing.
As for lots of rubber between potholes and rim, if tire is properly inflated it's no bigger an issue than a smaller wheel with higher profile. Under inflated tires suffer more readily from "rim pinch" than just sidewall height. FWIW it's only a difference in most cases of a 70 series to 65 or 60 series.
Don't overload, drive too fast, or follow too closely. Potholes are easier to avoid and less harmful if following these practices.
Old 04-15-2024, 04:58 PM   #18
Generally speaking, true.
Not the case in all tires, nor for all people towing. I occasionally tow with a 35 series tire (I know, I know ... but I do). Not much flex, truly, and the rim is a LOT stiffer, but you find the right pothole or curb, I assure you, a pinch flat on 22"s with 35 series tires (say, 285/35R22) is most more likely in your future than with a nice, comparatively tall 60 series. Towing or not.
Again, the details may diverge, but ultimately we agree.
Old 04-15-2024, 06:21 PM   #19
To "channel" fellow menber here, airdale, can you name a pickup brand/model that has on it's door sticker a tire with a 35 aspect ratio in it's size? On some specialty trucks like the Ford Raptor you can find OEM 55 aspect ratio tires on a
20 Inch wheel but 33" with 35 aspect ratio?? 22" wheels are usually aftermarket and non-hub centric as well which brings on other problems.
That sticker shows the sizes the manufacturer " certifies" for that vehicle with the regulators.
Old 04-15-2024, 06:32 PM   #20
My 2019 F150 with max tow/haul has 13,200 tow and it has 18" factory wheels. I have the original window sticker that states that tow capacity.
BarabooBob is offline   Reply With Quote
tow, towing, wheel
