Originally Posted by moose074
I would say informative, I do wonder the effect of the out of scale hitch on the car as it looked as if hooked to the axle, then on the Jeep the trailer a frame looked really long. In this video and the one similar seen several times before I always wonder what the absence of weight ( no walls fridge doors furniture ect) has on the test as both car and trailer lack weight except the one they move. Finally I wonder about the teather does it keep it from getting worse or does the yanking it back to the middle multiple the effect instead. Just question from uneducated
As I understood the narrator, the tether is unrealistic in that it prevents the tow vehicle from being yanked around. If it weren't there, the combination would have gone off the road and "inverted."
The tether is necessary, of course, for the simulation. Otherwise you would need a really long, flat course, and if you wanted to change weights in the middle of the experiment you would have to run after the experiment.
I've got a
belt sander with a pretty long platform. I was thinking about putting on a real fine-grade belt and re-doing these experiments. The belt swings from horizontal to vertical so I could do the uphill (and maybe downhill) experiments too.
