Originally Posted by Saturn V
I put on Airlift 5000 last spring. They work great and are not too hard to install. I fill mine up to about 70 PSI when towing and they really absorb the bumps. I disagree with the last post though. I initially had separate fill valves for each bag, but thought it was a waste of time filling both separately and having to go back and make sure they are even. I installed the T union and really happy with it. If you haul uneven loads then separate valves might be necessary.
I also T'd the lines to my Airlift bags. No sway, reduced bounce on my 03 Chevy Duramax. Improved ride dramatically. I ran the lines up into my console with a ball valve and Schrader valve. I can reduce air pressure from the cab after dropping the trailer. I use an auxiliary battery charger from Harbor Freight that has a compressor included.
https://www.harborfreight.com/5-in-1...art-62747.html
It gives me the option of having a jump starter and tire inflator if needed. I hook it up
WITH the trailer load on the truck and inflate the bags to 60 psi. Have run this setup close to ten years without issue. I would say the built in compressors are nice, but somewhat complicated installation wise. I have heard stories of failure for them but would be convenient. Those systems also have the bags T'd.
