Originally Posted by XenoRev
I set my ram 1500 and WD up before I had air bags. The AB were a gift from someone who had traded trucks and couldn't use them anymore.
No wanting to change my setup I only put 5-7psi in the bags to stiffen the ride. Doesn't change the height, but reduces bobbing on bad roads. And Michigan has plenty of bad roads.
Sent from my SM-G950U using Forest River Forums mobile app
I know a lot of people that have installed air bags on their pickups to increase the load capacity. Wrong approach.
Yes, the airbags will keep the tail end from sagging but the tires and rear axle aren't any stronger than before the bags were added.
Only reason the airbags should be used is to keep the rear suspension from bottoming out when hitting dips or bumps. The air bag is a progressive spring and really only increases the stiffness as the air bag is compressed.
Over inflating them to raise the rear is just asking for trouble if the load was in excess of the axle's rating to start with.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change
