Old 04-23-2020, 01:21 PM   #1
Airlift Loadlifter 5000 Questions
Hello All,
I just had the Loadlifter 5000 airbags installed on my 2019 RAM 1500, to level out the truck when pulling our 2020 2512s Mini Lite. ( Trailer seemed to drop the rear of the truck about 2")
Unfortunately, there are NO INSTRUCTIONS on use of the airbags.....so:
1. Do I inflate the bags before or after hooking up my TT?
2. Do I need to reconfigure my E2 sway/distribution hitch once truck is level from inflation of airbags? If so, are there instructions for this? The dealer set it up originally when I purchased the trailer.
Thanks in advance for any info that you can provide.
Dreedo is offline   Reply With Quote
Old 04-23-2020, 01:42 PM   #2
GoneSouth10's Avatar
Jeez - somebody edit the title of the post!! I thought you had "5000 questions" about the "Airlift Loadlifter"!!
Talk about the coronavirus giving you too much time on your hands!!
2015 Berkshire 34QS
GoneSouth10 is offline   Reply With Quote
Old 04-23-2020, 02:10 PM   #3
LOL The model name is Loadlifter 5000!
Old 04-23-2020, 02:28 PM   #4
2015 Berkshire 34QS
Old 04-24-2020, 12:36 AM   #5
You inflate before you hook up the WDH. Unless you have the 5000 Ultimate with the internal jounce bumper you need to always keep at least 5 psi in the bags at all times. For what you're towing, the Air Lift 2000 would have been more than adequate.
2019 Silverado LTZ 1500 6.2L 3.42 Max Trailering Package
2018 Freedom Express 192RBS
2016 Silverado LTZ 1500 5.3L 3.42
2015 Jeep Wrangler Rubicon 3.6L 4.10
2020 KZ 130RBSE
AlaskaErik is offline   Reply With Quote
Old 04-24-2020, 06:24 AM   #6
FordHauler's Avatar
And now I can carry 5000 pounds more than my truck is rated for! High fives for me!
Travel safe
2019 Ford F-350 Super Duty CC Dually 6.7 Diesel
2011 Cedar Creek 36CKTS Touring Edition
I Catch Fish......What is your SuperPower?
FordHauler is offline   Reply With Quote
Old 04-24-2020, 07:35 AM   #7
I detect your sarcasm. Truck is rated for 12,500... trailer is 5,200 dry. I did not install the loadlifter air bags to carry more weight... just wanted to level out the truck so the headlights don't blind oncoming traffic
Old 04-24-2020, 08:04 AM   #8
Capt. Mike's Avatar
I always inflate my Firestone airbags after hooking up, but before I move the truck. That way, as I inflate to 50# I can actually see my truck rise a little bit.
And I'm towing a fifth wheel, so adjusting the WDH for the inflated state is not something I have to worry about. However, I would think that your dealer set your hitch up for level towing. So, if the airbags bring your truck/trailer combo back to "level", no adjustment to the WDH would be needed.
Mike and Yvonne
and Sophie, the little white dog
2017 Columbus 320RSC
2015 Chevy Silverado 2500HD Duramax 4X4
ďIt's not how old you are, it's how you are old.ĒJules Renard
"It's not the years...it's the mileage." - Indiana Jones
Capt. Mike is offline   Reply With Quote
Old 04-24-2020, 01:19 PM   #9
FordHauler's Avatar
Sorry Dreedo that was not aimed at you. Just an off the wall comment, thinking out loud. I guess I got out of bed on the smart ***** side today. Too much energy that needs to be worked off and no place to GO do it. We will get thru this shutdown and I am ready to hook up and GO. ASAP. Anywhere!
I have those same airbags on my F-150 that I used to pull my TT with. I too hooked up and then aired up. Donít know if I was right or wrong.
Travel safe
Old 04-24-2020, 01:33 PM   #10
Travel safe
All Good, we are all experiencing stress these days! I too am anxious to actually be able to use my TT that I've only used once since purchase!
Appreciate the info on the Airlift! Thx
Old 04-24-2020, 02:20 PM   #11
DouglasReid's Avatar
We have a 5er not a TT so no WD hitch, but.........the last thing I do when hitching is air up the airbags.
Like someone said, I do it to level the truck so it sits when loaded the same as it does empty. Don't want my headlights blinding oncoming traffic.
I just air them up til the squat is gone.
It also has the wonderful effect of improving the ride.
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is online now   Reply With Quote
Old 04-24-2020, 08:57 PM   #12
FordHauler's Avatar
I forget all of those reasons I installed the bags on my F-150 now that I have the new dually. I remember thinking about putting them on my 2001 F-350 because this 5er did make that old truck squat. I donít like to be blinded by those tail-draggers either, however I seem to think that everyone has on their hi-beams with the new technology type headlights.
Thanks to AlaskaEric I plan to check the air pressure in those bags on the F-150 tomorrow. Minimum 5 pounds you say?
Travel safe
Old 04-25-2020, 06:00 AM   #13
I have a 2500 tow a 11k tt with a wdh antisway. My hitch setup to get me where i should be and the airlift bags are aired up to 35# just to assist the suspension. I do not use them to level me off cause then that would defeat the purpose of my wdh.
cmysstailights is offline   Reply With Quote
Old 04-25-2020, 06:58 AM   #14
Not true. The WDH is dong just what its name says it is,it is distributing some of the weight fro the rear axle to the front.
It can and most often does leave some squat on the rear axle, the air bags can remedy that issue.
Which is one of the reasons I air mine after hitching.
Not to mention that if I aired them up first Id just have to elevate the nose of the camper that much higher to get connected.
This way there is no guesswork, I simply air them til level, one and done.
Old 04-26-2020, 10:20 AM   #15
I have the Airlift system on my 2500 Chevy. I tow a Fifth wheel so can't answer your hitch question, but I air my bags up for level, and ride comfort. I set my bags up where one fitting feeds air to both bags. Works better than individual air fittings for each bag. Always increase or decreases height evenly. I also wait to air up until the trailer is hitched. 60 psi unloaded raises the rear of the truck to the moon making it hard to hitch as the trailer has to be so high. You do need to be careful that you don't crush the bags all the way down, as you will pinch the bag and cause a leak if they don't have the newer internal stop to prevent that. My truck doesn't deflect that far, so not a worry for me. I also installed a ball valve to dump the air, as is much quicker when we unhitch. The air lines are aircraft style, and all the fittings are readily available at NAPA or other auto parts outlets. I have used this system on my truck for over 10 years and still love it.
2003 Duramax
2017 Crusader 315
2016 Boston Whaler Montauk 150
Former Montana owner
Colorado Cruiser, Over the Pass and Down the Hill
Comanchecreek is offline   Reply With Quote
Old 04-26-2020, 11:11 AM   #16
Thanks for the info! Great ideas on the ball valve. I might have to reconfigure so that one valve fills both at the same time as I have 2 different valves to fill. Should have thought of that before!
Old 04-26-2020, 01:58 PM   #17
These are the style of the fittings. You just need to match them with the hose size. I picked up all of my parts at NAPA, but you can find them most anywhere.
https://www.amazon.com/Tailonz-Pneum...rd_i=580146011
2003 Duramax
2017 Crusader 315
Old 04-26-2020, 06:49 PM   #18
One thing to watch for when plumbing a single inlet.... there can be cross talk between the bags when cornering. The bag on the outside will try to compress, and will pump some of its air to the inside bag, making the inside want to raise. It might not be noticeable on a truck with a stiff ride like a dually, but with high-ish bag pressure on a softer truck likean F150, you'll notice it. Particularly when empty.
Easiest solution is the dual inlets. I never do tings the easy way apparently...I tried teeing them into a single fill valve and learned about the cross talk. I then used a ball valve in one of the lines to separate my bags, and kept them teed into one fill valve. I open the valve and fill both bags at the same time, then close the ball valve on the one line, and the bags are seperated.
2019 Rockwood MiniLite 2104S
2017 F150 3.5 EcoBoost 10 spd 4x4
SmittyCorp is offline   Reply With Quote
Old 04-26-2020, 09:07 PM   #19
I've got a single point inflation valve on my 2016 Silverado 1500 with Air Lift 2000 bags and I've never noticed anything like that. With separate inflation valves the risk is one bag going flat. I'd rather have both bags go flat if a leak develops. Most people aren't going to put in an isolation valve. And if someone does, they're right back to a leak leaving them with an imbalance.
2020 KZ 130RBSE
Old 04-26-2020, 11:39 PM   #20
I was told by the shop i bought my air bags from to NOT INSTALL both valves unless i was going to put in a truck bed camper. But if pulling a fifth or tt to only install one valve.
Scoob is offline   Reply With Quote
500, lift
