Old 10-01-2019, 06:02 PM   #1
Andersen shank question
This might be a dumb question, but which hole should I use when mounting the shank of my Andersen No Sway WD hitch? I can slide the shank in all the way and use that hole, or pull it out 2-3" and there's another hole. I assume either is acceptable, and determined by the required distance from ball and TV? Is this correct?
HotBacon is offline   Reply With Quote
Old 10-01-2019, 06:38 PM   #2
Multi-Slacker
Either position works (I know from experience). I, too, assume that one would only use the furthest out position to ameliorate jackknifing issues.
2017 Forest River Sonoma 280RKS
2018 Silverado 2500 HD 6.0L, 4:10 rear
CurtPutnam is offline   Reply With Quote
Old 10-01-2019, 07:18 PM   #3
DieselDrax's Avatar
I'm of the opposite mind, I would run the hole that allows the ball to be as close to the rear of the TV as possible without making contact so as to reduce the leverage put on the TV by the trailer tongue weight. The further from the rear axle the more leverage is put on the TV.
But, ultimately, use whichever one works best for your setup. I don't think there's any right answer...unless Andersen says there is. I'm not seeing any reference to which hole is recommended in their install guides. I've been using the hole that puts the ball closest to my truck's rear axle with my Andersen hitch.
2017 GMC Canyon - CCLB, 4x4, 2.8L Duramax, ARE Z-series shell
2013 Shamrock 21SS
DieselDrax is offline   Reply With Quote
Old 10-02-2019, 06:50 AM   #4
I don't see anything in the install guides either, which prompted me to ask the question.
When installing the brackets on your trailer, did you install the bolt heads on the outside or the nuts? The install guides say to have the bolt heads outside, but the newest Andersen install video on YT specifically says to do it the opposite way. The explanation is to prevent the bracket from walking back while tightening the nut, but I think that is exactly what you would want.
Old 10-02-2019, 07:06 AM   #5
Rookie
Mrprovy's Avatar
I asked a similar question in another thread, as I too am curious. Someone posted that the further out the shank is, the more bounce may be felt (makes sense). In my case, with my spare the swing out arm, I may have to mount it so the shank/ball sticks out further so I will be able to open my hatch with the trailer attached.Click image for larger version
2006 Chevy Trailblazer
2020 Geo Pro 16BHG
Mrprovy is offline   Reply With Quote
Old 10-02-2019, 07:36 AM   #6
thebrakeman's Avatar
The closer the ball is to the rear axle, the more stable the rig. That's why a fifth-wheel is so stable. Use the hole that brings the ball closest to the rear axle, unless that causes interference with any components during turning.
thebrakeman is offline   Reply With Quote
Old 10-02-2019, 07:41 AM   #7
marinerjoe's Avatar
I must have an older model. I got mine in 2018 and there’s only one hole for the hitch pin in mine.
Joe
Current: 2020 Rockwood MiniLite 2205S
Past: 2018 Flagstaff MicroLite 21FBRS
Past: 2005 Flagstaff Classic 625D
TV: 2016 Ford F-150 3.5 EcoBoost
marinerjoe is offline   Reply With Quote
Old 10-02-2019, 10:06 AM   #8
DieselDrax's Avatar
I have the bolt heads on the outside and the nuts inside. If you hold the bolt still and only wrench the nut then the bolt won't walk the plates anywhere.
So far I've been really happy with the Andersen, I replaced a Fastway e2 with it. The e2 worked well enough but I was having problems with the brackets shifting on the trailer frame and the weight of the hitch head was aggravating a back injury and the Andersen killed 2 birds with 1 stone.
2013 Shamrock 21SS
Old 10-02-2019, 11:50 AM   #9
Multi-Slacker
I do not think we are of opposite minds on this. What I wrote must not have been clear. To restate, I believe the ball should be as close to the receiver as possible as long as no components will be damaged during turns.
Old 10-02-2019, 12:23 PM   #10
D W
D W's Avatar
Here's a novel concept: Set your hitch up so you can open the tailgate of your TV. More and more, I see folks that short-shank their set-ups and can't open their tailgates when hitched.
2016 Salem 27RKSS
D W is offline   Reply With Quote
Old 10-02-2019, 01:01 PM   #11
Multi-Slacker
Cannot do it with our TV and TT
Old 10-02-2019, 02:57 PM   #12
Here's a novel concept.
That's what I thought the second hole was for. But as I pondered it, I could see the leverage differences and everything else mentioned by others. Which is why I asked the question in the first place.
Old 10-16-2019, 04:19 AM   #13
Rookie
Mrprovy's Avatar
I definitely needed the second hole to bring the shank out further. I can get a tiny bit of swing, just enough to open the glass, but there's no way I can get my tailgate open with the trailer hitched. At full right turns, the the contacts the propane tank cover.Click image for larger version
2020 Geo Pro 16BHG
