Old 09-29-2019, 12:33 PM   #61
nutdriver's Avatar
Originally Posted by Jay2504 View Post
Thank you nutdriver. I was thinking leaving the chain nut adjustment alone once I got it set. Just pull the pins and leave the chains on the camper. Please keep in mind that I do not use a wdh on my current trailer, this would be for the next one with maybe 800-850lbs tounge weight. Jay
Jay - I think you will find that it is not a big deal to remove the nuts. They use a very robust coarse thread that works well and it makes removing the nut very quick. Once you start pulling your new trailer, your connect and disconnect technique will emerge quickly.
2019 Freedom UltraLight 192RBS
2018 Sierra 2500HD Duramax
Anderson WD Hitch
TST 507 TPMS
nutdriver is offline   Reply With Quote
