11-23-2016, 05:38 PM
Anderson WDH With Picts
I decided on the Anderson set up and thought I would post the info here.
My tv is a 2004 Lexus GX470 and is the lightest duty tow vehicle I have ever used to tow with. I never liked the feeling of the tail wagging the dog. So I did a little research and decided the Anderson should work on this short wheelbase vehicle, and the Rockwood 2306 which is around 4500 to 4700 lbs wet.(I haven't been to the scales yet so this is just a guess...) The install went well, and took around 3hrs. I posted a few picts. One pict is showing the set screw location. I drilled the trailer frame to create an indent that the set screw could seat into. I towed around 130 miles this weekend and overall it worked pretty well. I spent about 4hrs test driving the rig, before the trip, taking measurements of the trailer and tv height at different settings.I got the front end dropped around 3/8 of an inch when hooked up. The truck is running Air Lift bags in the rear, so I settled on about 45 psi in the bags. I plan on calling Anderson after the Holiday weekend to verify my install. I really like not having to haul around the old style WDH.The set up is easy, with no heavy lifting to do. The triangle piece and chains just un hook with a cotter pin and your done, no bars to remove or deal with.
2018 Toyota Tundra Crewmax
2017 Mini Lite 2509S
2012 Mini Lite 2306, 2000 Storm 32ft Class A w/dbl slides, 1998 Class C 23ft Fleetwood, 1990 8ft Lance.
Nights Camped 2016- 15, 2017- 30,2018-27, 2019-36 2020-21
11-23-2016, 06:55 PM
What about a Pic of the complete rig hooked up without the tongue jack supporting the middle! Youroo! !
11-23-2016, 07:30 PM
Picts of tt hitched up
The trailer jack is off the ground in that one photo. Here is a couple shots of it in the parking lot where I came back and took measurements etc.The trailer was level within 1/2 inch front to back. Not sure what the front end was doing in that shot. The first few go arounds proved the wdh was not adjusted correctly, as I had a pretty loose feeling up front.After measuring I confirmed the front end had not dropped from the unloaded stance. On the final adjustment, I was able to get the front end down around 3/8 to 1/2 inch from the unloaded measurement. The handling and ride improved also. I'm not certain its completely dialed in yet, but its pretty darn good.
11-28-2016, 01:39 PM
Noticed you have above 5 or so threads showing. If necessary don't worry about cranking them down more if need to shift the weight back to the front. The Andersen does not do a real good job of transferring weight. I love mine, and I have 9 threads showing.
George Scott
2015 Salem Hemisphere Lite 272RLIS
2006 Heartland BH 3400/Summer Home
2021 Sabre 37FBT
11-28-2016, 02:09 PM
Hey Scotty,
Yes. 5 threads is right on. I was wondering about cranking it down some more. Thanks for the heads up! So far love the way it has performed. Need to get it on the open hwy with a little wind to really see how it does. On this trip I had 3 bikes on the rear bumper with a hitch mounted carrier😳 had a full tank of water to try and counterbalance the bikes. Worked great. I have been looking at ways to move the bikes either inside where the dinette table is, or possibly up front on the trailer tongue with a mount...but that's another discussion altogether. 😃
11-28-2016, 02:11 PM
Originally Posted by ace911
Hey Scotty,
Yes. 5 threads is right on. I was wondering about cranking it down some more. Thanks for the heads up! So far love the way it has performed. Need to get it on the open hwy with a little wind to really see how it does. On this trip I had 3 bikes on the rear bumper with a hitch mounted carrier had a full tank of water to try and counterbalance the bikes. Worked great. I have been looking at ways to move the bikes either inside where the dinette table is, or possibly up front on the trailer tongue with a mount...but that's another discussion altogether.
So good so far. as long as the TV is on or within 1/2 inch of unloaded height and the steering feels solid and no sway you're good to go.
George Scott
2021 Sabre 37FBT
11-28-2016, 02:21 PM
Not sure how you can compare number of threads showing. If he had installed the frame members 1/2" forward or backward, seems the thread count would be different.
2011 Traverse LT, 3.6L, FWD
11-28-2016, 02:57 PM
Roo. Yes thats correct. For the most part following the instructions, in a standard installation (if such exists) they have you extend the chains with brackets out along the frame as far as it will go. Thats the starting point from there. Then I would imagine the weight the the TT and TV would play into how much force is generated against the WDH?
