Another Sidwinder Question
I have activated the Sidewinder on my Rockwood Fifth Wheel, and I'm using a Reese Elite Hitich. I have problems hooking onto it occassionally, and almost always have problems getting the hitch to release the sidewinder. More often than not, I've got to release the holding pins on either side of the plate, raise the front of the 5th wheel until the pressure is released from the unit, and then I can open the front hook, releasing the plate from the sidewinder.
Reese has a single hook jaw that holds the kingpin in place.
I ran across a newer version of the B&W hitch, one that is mounted like a normal hitch, rather than relying on the single pin in the center of the hitch. I believe it is this B&W hitch that is approved for Sidewinders.
B&W uses two jaws that meet together in the middle to hold the kingpin in place. I'm thinking about changing to one of these, in the hope that I'll have less drama everytime I go to unhook from my trailer.
Does anyone use the B&W? Can anyone speak as to the difficulty or ease of unhooking with this system?
