Old 12-01-2023, 01:37 PM   #41
gw1800's Avatar
Originally Posted by TowPro View Post
I used to tow a 7x14 box trailer, dual axle, 7000 lbs loaded behind a 2008 Dually. Sure that combo did not "need" a WTH but it sure made a hell of a difference in the ride and handling when I used it.
I agree. But try to convince others. "I have big truck and don't need the WDH"
When I replaced my low end WDH, with the Equalizer, it make a big difference. It was fairly expensive, but the results were dramatic.
Western PA
2015 Silverado Z71
2018 toy hauler
gw1800 is offline   Reply With Quote
Old 12-02-2023, 08:40 AM   #42
OK this is my experience I own a ram 2500 pulling a 10,000 pound travel trailer at speeds below 70 to perfectly once I exceeded 70 I had terrible sway. I purchased weight distribution fix the problem. And then moved onto two different halftime trucks using the same weight distribution. When time to upgrade to a fifth wheel I bought a Ford 350 I towed the same travel trailer with the 350. Until we found the 5th wheel we wanted. I figured that the 350 I would not need the weight distribution.. an hour after I started my trip I was on the side of the road installing the bars. . Both the ram and the Ford pulled the trailers. I never felt this way however, looking in my side view mirror the trailer was ping-ponging between the lines just my experience..
2022 Chevy 3500 Diesel SWD
2022 Columbus 329 DVC
moose074 is offline   Reply With Quote
airbags, tow
