We have a 2020 287BH (as I understand it, they stopped making the 264DBH and turned it into the 287BH, so they are quite similar in design/floorplan, but I dont know that for a fact), but they attached the light strip right to the fiberglass wall of the trailer. Perhaps it was a change because of the poor design you are referring to. I honestly cant remember ever seeing it attached in the manner you are having an issue with. Seems like a weird design. Only suggestion I could offer is to use the 3M double sided tape for automotive use (it is the same tape they use for the vent visors around the windows, and can be used for attaching emblems and such). Its good stuff. If I were in your situation, that is what I would do.
But, this is a good opportunity for you if you wanted to change out the lights from blue to white. If I was in your situation I would probably switch them to white before reattaching them. We think they look awesome blue, even put our own blue lights underneath the chassis, but, functionally, if you are outside doing stuff under the awning in the dark, the blue is a nightmare to be able to actually see what you are doing (but it does create some pretty cool affects, we have a pink dog leash that glows orange, and a lime green extension cord that also glows bright fluorescent green). Hope it works out for you.
_________________________
2023 GMC Sierra 3500 Denali
2020 Cherokee Arctic Wolf 287BH
