B&W Question
Got what I think is lucky and found a 20k B&W Companion for my ford puck system used for $300 today. Installed easily and went to open the jaws with the lever and the jaws didn't move. The lever moved freely, was able to use a pry bar with little force to open them. Back into my king pin and they closed and locked. Pulled the lever and they released just fine. Think it needs lubricated or something? They also had what looked like a little bearing grease on the two pads under the head is this a normal grease point? Thanks all
