Old 08-07-2019, 02:07 PM   #21
Grammar Pedant
67L48's Avatar
Equal-I-zer 4-pt WDH. I leave my bars in place when backing up. I crank angles without issue. In fact, not only can you reverse with the WDH in place, it's specifically designed/advertised to not require removal prior to backing up -- it's a core function of the product.
Former RV: 2018 Rockwood Mini Lite 2504S
67L48 is offline   Reply With Quote
Old 08-15-2019, 08:29 PM   #22
Same here ... never unhook the bars when backing up. Never an issue either.
Dakota 1120 is offline   Reply With Quote
Old 08-15-2019, 10:00 PM   #23
smitty31093's Avatar
Backing with sway hitches
There are lots of weight distributing hitches. Some have the sway control built in to the shank and some have a sway control that mounts out to the side of the shank and the trailer frame. It has been my experience that you need to keep you weight distributing arms in place as long as you are moving your trailer, whether you are pulling forward or backing up. If your WDH has a separate sway control, yes, you need to release it when you are making sharp turns or when backing. If your sway control is an integral part of your weight distributing hitch you need to back up with it still hooked up. Some hitches like some Equilizer Brand hitches may require frequent greasing of the swivel points in the hitch head. If your hitch needs greasing you will probably feel your steering wheel pulling one way or the other when traveling down the road. Hope this helps.
Steve & Paula Smith
Warner Robins, GA
New 2016 Vengeance 320A
Previously owned: 2014 Vengeance 25V, 2011 KZ 184,
2011 DIY 7 x 14 Enclosed Trailer,
Motorcycle pull behind cargo trailer with tent
smitty31093 is offline   Reply With Quote
Old 08-16-2019, 09:12 AM   #24
Andersen WDAS hitch does not interfere
Sorry for your issue- that is specifically why I got the Andersen Manufacturing hitch system. Everything is integrated and even my demure wife can easily connect & disconnect the tow vehicle but backing anywhere is not an issue.
Also their service department is outstanding!
JPSJR is offline   Reply With Quote
Old 08-16-2019, 09:41 PM   #25
Andersen WDH is great, use one on my other trailer, no grease, no noise, little weight, great sway control.
LawlessFly is offline   Reply With Quote
Old 08-19-2019, 02:01 PM   #26
Take it easy,but take it
I remove mine for backing..Because i always have-no biggy-they gotta come off anyway !
Nickrenfro is offline   Reply With Quote
hitch, sway
