06-01-2021, 11:40 PM
Beginner Query
We just bought a 2021 Palamino Puma Destination trailer, and when picking it up from the RV dealer, we could not get the trailer hitch/coupler high enough to attach to the truck so a worker on a fork lift raised it up and we have to put blocks under the trailer hitch to get that height. We were told that we would have to keep 5 blocks under the trailer hitch or it would not get away to let the coupler hook to the truck. The truck is a 2020 Dodge Ram tradesman style 2500. So when the parked the RV and leveled it then detached, we put the five blocks under the trailer hitch as directed, but we cannot get the rv leveled now because the nose is too high. We put leveling block under the tires and nothing works. We put cement blocks under the scissor jack we have. Do we need to buy a different trailer hitch so we can lower the trailer down more in the front. Any help would be appreciated because we have to get this beast leveled.
06-02-2021, 12:17 AM
I don't know how heavy your trailer is, but I use an aluminum adjustable hitch. Mine is rated up to 10K. It makes it easy to adjust for my yard trailer if going to the dump, or other trailers.
I now use a weight distribution hitch up to 14K and that also has different heights that can be set.
06-02-2021, 12:51 AM
I drive an older model Dodge Ram 2500 and don't have the problems you say you are encountering. Is yours perhaps a 4 wheel drive and/or you have oversize tires and/or a lift installed?
Can you post a pic of your truck and hitch setup? Thanks
2011 Flagstaff 831 RLBSS
06-02-2021, 05:23 AM
I would suggest a good quality drop hitch, get the trl level then measure height from ground to bottom of hitch. We will say 17”. Now measure height of truck hitch say 21” . Now hook up trailer measure distance from ground say it’s drops to 18” inches then you need a 2 inch drop if my math is correct . If you still need the extra trailer tongue height then try this raises tongue up to 6”
2022 Chevy 3500 Diesel SWD
2022 Columbus 329 DVC
06-02-2021, 05:58 AM
Our trailer is about 11,000. What kind of aluminum hitch on the trailer do you use? Did you replace the original one that came on your rv?
06-02-2021, 06:00 AM
Originally Posted by moose074
I would suggest a good quality drop hitch, get the trl level then measure height from ground to bottom of hitch. We will say 17”. Now measure height of truck hitch say 21” . Now hook up trailer measure distance from ground say it’s drops to 18” inches then you need a 2 inch drop if my math is correct . If you still need the extra trailer tongue height then try this raises tongue up to 6” Attachment 255934
Thank you so much for the information!!
06-02-2021, 06:03 AM
Not a problem I would suggest a WDH with sway control, however if you are happy with how it towed it may not be needed.
06-02-2021, 06:05 AM
It is a four wheel drive and the hitch on the truck is a weight distribution hitch with stabilizer bars that they put on at the rv dealer. I will have to add pics later.
06-02-2021, 06:17 AM
I have similar 4wd Ram with Equalizer WDH. Had to order a new shank from Equalizer with a 9 inch drop to level it out when I traded off the Ford 2wd..
Destination RV's are normally meant to be towed to a site and left for long periods of time. If that's the case with your RV and you're not going to be moving it, then you can use a bottle jack to hold the tongue up and remove most or all of the blocks under the tongue jack and lower the tongue to get the RV leveled.
As eluded to above you need to get a drop shank for your particular weight distribution hitch so that the RV tows level when you tow it.
Post pics of the truck, Weight distribution hitch, and RV tongue and we can help you figure this out.
Gotta go campin!
06-02-2021, 06:21 AM
We have one that they put on at the rv dealer with weight distribution and sway bars.
06-02-2021, 06:37 AM
We are staying in one place for about 3 months then moving to another state but staying at that location permanently. I will post some pics in a bit. I really appreciate the info and help!
06-02-2021, 06:38 AM
Ok I will look into those, thanks!!
06-02-2021, 07:16 AM
I was afraid of this as I was figuring the dealer did not properly level the WDH (weight distribution hitch) when installing it to your vehicle....since you probably required some kind of drop shank to do it properly due to your trucks height.
This may give you an idea
06-02-2021, 02:26 PM
Ok thanks!! And that would not surprise me
06-02-2021, 02:31 PM
Pics
Here are pics
06-02-2021, 02:35 PM
Mopar Guy
i bet that height of hitch is pretty close. If it were me, id use a floor jack to support the tongue while you remove blocks or stack block under the tongue to support while you remove the blocks
Dave
2019 Grey Wolf 24JS- sold
1998 Holiday Rambler Imperial 41wds
06-02-2021, 03:09 PM
RV There Yet?
2018 17RP
2009 Crew Cab King Ranch F150 "Goose"
06-02-2021, 03:11 PM
Would that bulldog power jack work that is in that video posted here? That’s looks like it would be good to me
06-02-2021, 03:15 PM
Originally Posted by IsleDog
Ok thanks!
