Old 05-18-2019, 09:38 PM   #21
frank4711's Avatar
Check my signature... thanks
Frank & Cindy--- (SOB) 5th Wheel ---2019 Ram 3500 Cummins 6.7 SRW 4x4 8' bed--- Payload 4394------Remi & Sage camping pups---TST 507 TPMS ... B&W Patriot 18K---3.73 axle ... Predator 3500---2019 48 days ---2020 28 days Camping
frank4711 is offline   Reply With Quote
Old 05-22-2019, 02:22 PM   #22
The treads on these general tires are:
FL 6/32
FR 9/32
RL 4/32
RR 7/32
I think the old rule of thumb was replace at 2/32... but I am about to start towing. I am on the fence about replacing tires right now because we have a lot of money going out with the 5th wheel purchase.
Would you guys replace at these levels?
parver is offline   Reply With Quote
Old 05-22-2019, 02:58 PM   #23
I just installed Michelin Defender LT 265/70/18 on my Silverado. I need to buy a new spare
spock123 is offline   Reply With Quote
Old 05-23-2019, 02:27 PM   #24
frank4711's Avatar
Oh snap !!! I forgot the spare will order this week ... I bought the same tires
Old 05-23-2019, 02:44 PM   #25
rracer5's Avatar
I'm on my second set of Cooper Discoverer A/T3. I was so happy with the first trouble free set, I got them again!
2014 Prime Time Sanibel 3250
rracer5 is offline   Reply With Quote
Old 05-23-2019, 04:32 PM   #26
265 is the oem tire size. I've heard costco giving people trouble if you are not putting on exactly the size tire the manufacturer uses. Any experiences with this?
Old 05-23-2019, 06:50 PM   #27
My spare has been plugged twice and one inside patch. DW said buy a new tire for the spare
Old 05-30-2019, 08:06 PM   #28
Thanks to all the replies. Based on the feedback, I went with the Michelin Defender LTX M/S. I stuck with LT275/70R18. That was on it before, even though the OEM is a 265 as discussed earlier.
The sticker on my door jamb says
FRT 60 PSI
RR 80 PSI
SPA 80 PSI
The tire shop inflated everything to 60 psi. Sounds like the rears should be at 80 psi, is that right? and I am assuming SPA is the spare? I didn't replace that, but I need to... it looks pretty old.
ID:	205989   Click image for larger version
Old 05-30-2019, 08:27 PM   #29
FRT 60 PSI
RR 80 PSI
SPA 80 PSI
With the truck empty 60 to 65 is fine for the rears . once you load the truck then up the tires psi . Benn running the michelin denfender on my truck since last fall . best riding tire i ever had on my truck and looks to be wearing very well
MR.M is offline   Reply With Quote
Old 05-30-2019, 08:31 PM   #30
Thanks, good news. So technically I should bump them up to 80 psi before towing around the 5th wheel? How many people do this? Add/release air when towing?
Old 05-30-2019, 08:42 PM   #31
frank4711's Avatar
I run 65 front and rear go up to 75 when I tow .... good choice
Old 05-30-2019, 09:08 PM   #32
On my first set and so far so good. I would recommend and buy again.
The Michelin’s are great too. I had them in my previous truck.
That said, I got the Cooper’s for half the price of the Michelin’s with the same warranty. I can’t say that the ride is any worse. It’s a heavy duty truck. Not much you can do And for the savings I would do it again.
Kf4mnc is offline   Reply With Quote
Old 05-30-2019, 09:19 PM   #33
I run 65 front and 62 rear when empty. I'd go to 60 on the rears empty but my TPMS flags at less than 62.
Towing I bump the rears to 75.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 05-30-2019, 10:29 PM   #34
I’m lazy I normally run 60psi in the front tires and 80psi in the rear. 80psi in the spare. The Michelin tires I just installed run great, tomorrow morning I’m getting a new spare
Old 05-31-2019, 11:57 AM   #35
rracer5's Avatar
Since I don't use my truck as a daily driver/commute, I just leave the rears at max. towing PSI recommended on the door sticker. If you use it everyday then I would reduce the rears to give a slightly smoother ride & better tire wear (less wear in the middle of the tire).
X2
Old 05-31-2019, 12:37 PM   #36
B and B's Avatar
Run 80 in rear all the time, never let air out when dry.
Old 05-31-2019, 03:50 PM   #37
That's what i do . 65 to 68 when not towing and 80 when towing . everyone will have their own idea on how it should be . this is where common sense comes into play . no one is right for everyone and the psi set points can be argued till hell freeze over and still no one wins
Old 06-05-2019, 06:25 AM   #38
I’m just a little curious but what does the blue color around the the new Michelin tires mean? The factory the tires were made at? The tires were $215 eachClick image for larger version
ID:	206484Click image for larger version
Old 06-05-2019, 07:36 AM   #39
wmtire's Avatar
I’m just a little curious but what does the blue color around the the new Michelin tires mean? The factory the tires were made at? The tires were $215 eachAttachment 206484Attachment 206485
https://www.tirerack.com/tires/tiret...jsp?techid=173
2011 Flagstaff 831 RLBSS
Old 06-05-2019, 07:48 AM   #40
Originally Posted by wmtire View Post
tire, tires, tow vehicle
