Old 08-02-2017, 07:58 PM   #1
SecretSquirrel's Avatar
Bogus cargo capacity sticker
So below is the CCC sticker from my 2006 f250 6.0 diesel. Tell me it's not wrong. No way in heck can 461lbs be correct. Your "5 passengers" alone would have to be under 100lbs each..
_________________________
Crusader 337QBH
2019 F350 6.7L DRW CC LB 4x4 Lariat
B&W Companion 20K for OEM pucks.
SecretSquirrel is offline   Reply With Quote
Old 08-02-2017, 08:05 PM   #2
Wobbles's Avatar
Wow! Something real fishy there. I mean WOW! I think the POS Yugo had more CCC that that.
Bob & Michelle
2016 Ford F-250 Lariat 4x4
2017 Flagstaff Super Lite 526RLWS
Wobbles is offline   Reply With Quote
Old 08-02-2017, 08:09 PM   #3
rsdata's Avatar
heck... 16 KG is only like 34 pounds... someone messed it up
"Freedom is never more than one generation away from extinction. " - Ronald Reagan
Too much of anything is bad, but too much good whiskey is barely enough. Mark Twain
2014 Shamrock 183
Old 08-02-2017, 08:11 PM   #4
Wobbles's Avatar
Go here and put in your VIN# , its on your sticker in the picture...
https://www.etis.ford.com/vehicleSelection.do
It says you have the "10,000 LB. GVW"
Bob & Michelle
Old 08-02-2017, 08:17 PM   #5
GalsofEscape's Avatar
does it also say only 16 kg?
that does not make sense either as 461 lbs = 209 kg
HTT: "EscapeII" 2016 Shamrock 23WS (current)
PUP: "Escape" 2010 Rockwood HW 277 (gone)
TV: "Bruce" 2011 Dodge Durango V8 Hemi Crew
Just us gals (me, Sis and our daughters)
We spend alot of money to go sit in the woods
GalsofEscape is offline   Reply With Quote
Old 08-02-2017, 08:23 PM   #6
I wonder if it is supposed to be 461kg or 1016 lb.
2015 Sunseeker 3170ds
TakeItEasy is offline   Reply With Quote
Old 08-02-2017, 08:26 PM   #7
Originally Posted by Wobbles View Post
Go here and put in your VIN# its on your sticker in the picture...
Yes the vehicle could be 10,000 lb rating... BUT that is the tire specs rating not the truck, could be cheaper tires with a much much lower load index... if it is 108 load index then that is 4400 lbs on the front and rear if the curb weight on the front is 4000 and the rear is 2800 then yeah I could see a 461.
Time for some new tires
N6ZCM is offline   Reply With Quote
Old 08-02-2017, 08:26 PM   #8
Wobbles's Avatar
That sticker has been doctored... Not even the same font and note the KG's and LB
Bob & Michelle
Old 08-02-2017, 08:28 PM   #9
Who Dares, Wins
doc73's Avatar
Could be much more believable... I would (if it is yours) take it to a Ford dealer and get them to order a new sticker that is right. the 10k GVWR does not tell you anything. My truck is 10k GVWR but I have a 2500lbs payload.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 08-02-2017, 08:28 PM   #10
Who Dares, Wins
doc73's Avatar
The numbers are printed after the fact, the stickers are pre made.
2015 ChevyHD D-Max
Old 08-02-2017, 08:39 PM   #11
Blender's Avatar
Well what about the 16kg? Yea that's why I think those stickers are plain stupid just be smart and know what a 1/2,3/4, and 1+ tons are capable of.
Blender is offline   Reply With Quote
Old 08-02-2017, 08:41 PM   #12
Wobbles's Avatar
Just me going to the dark side. Hope the OP does go get that checked out.
Bob & Michelle
Old 08-02-2017, 08:42 PM   #13
Who Dares, Wins
doc73's Avatar
The problem is people are not smart and do not know what they can do hence the stickers..
OP: How long have you has this truck to just notice this?
2015 ChevyHD D-Max
Old 08-02-2017, 08:43 PM   #14
Blender's Avatar
Agreed! Noted!!!
Old 08-02-2017, 08:44 PM   #15
That's why it's called a "light truck"!!
John & Susan, Olivia the dachshund
2011 Georgetown 337DS
2003 Dodge Dakota
Hampton Roads VA
2016 174 Days camping, 2017 66 days 2018 24 days 2019 48 days
mogman is offline   Reply With Quote
Old 08-02-2017, 08:55 PM   #16
aufinger's Avatar
If I was going to guess, I say it should be 1116 KG which is 2461 lbs. Larry G.
2016 Toyota Tundra 5.7L DC
2016 Flagstaff Micro Lite 23LB
USMC (Retired) '70-91
aufinger is offline   Reply With Quote
Old 08-03-2017, 04:22 PM   #17
Yep, says that on the regular VIN label next to that bogus CCC sticker.
Crusader 337QBH
Old 08-03-2017, 04:37 PM   #18
Agreed! Noted!!!
To Doc73, thanks for the personal attack on my intelligence.
I posted this sticker up specifically because some on this forum like to point to like its gods answer to everything. It isn't. This one is obvious to the most casual observer that its incorrect. Most here agree with that. Was trying to simply point out that one shouldn't believe everything they read (on the internet or on their trucks!).
To the rest that replied, thanks for the replies. My actual VIN sticker does in fact show 10,000lb GVWR and 6100 rear GAWR and 5200 front GAWR. It does it fact have the size tire on the sticker although not original (I bought the truck used and have since replaced them). Load range "E" with max payload of 3185 at 80psi. So no issues there.
Like mentioned I might just take it to the Ford dealer and say "please explain this" and see what kind of answer I get. I'll have them get a new sticker just appease the CCC sticker police on the forum even though anyone with any sense knows it's wrong.
Again, thanks to those that just wanted to participate in nice conversation about it. Looking forward to conversing with you all again. I do believe there are a lot of people here with valuable input to provide, myself included. I'm not new to this. Been towing a 33ft Jayco TT for years....
Again, thanks everyone.
Crusader 337QBH
Old 08-03-2017, 04:54 PM   #19
Blog: RVroadtripper.com
hbillsmith's Avatar
It's a 3/4 ton truck so the GVWR should be 10,000#. Go to a truck stop and fill your gas/diesel tank. Then drive around to the CAT scale and weight the truck. Subtract the truck weight from 10,000 and the remainder is your true cargo carry.
Maxxis 235/80/16E; AirBags w/AirLift1; mor/Ryde Rubber Pinbox; Andersen UltimateII Alum. 5erhitch on Reese Flipball w/Curt 4" offset; LCI Ground Control3; King Dishtailgater; Traveling with 10' Portabote;
hbillsmith is offline   Reply With Quote
Old 08-03-2017, 08:17 PM   #20
Who Dares, Wins
doc73's Avatar
Not sure what part is a personal attack but whatever my friend, enjoy.
2015 ChevyHD D-Max
cargo
