Old 09-21-2020, 07:39 PM   #1
Brake controller
Whatís everyone think about my needing a brake controller
I have a Nissan Xterra pro-4x. V6. I bought the 2020 forest river Rockwood 1640 esp. Iím not sure if I need that but welcome any feedback.
Seems like an easy install either way just donít know if I want to spend the mullah on that if itís not needed.
Thank you!!
Lpaine1331 is offline   Reply With Quote
Old 09-21-2020, 10:08 PM   #2
bikendan's Avatar
Tekonsha P2 or P3.
Old 09-22-2020, 01:03 AM   #3
Yes, you need a brake controller. And a 7 pin plug, if you don't already have one. Trucks like that may only have a four pin plug. You don't want to find out during an emergency stop or going down a steep hill that your tow vehicle doesn't have enough braking power. I have a Prodigy 3 and think it works great.
2019 Silverado LTZ 1500 6.2L 3.42 Max Trailering Package
2018 Freedom Express 192RBS
2016 Silverado LTZ 1500 5.3L 3.42
2015 Jeep Wrangler Rubicon 3.6L 4.10
2020 KZ 130RBSE
AlaskaErik is offline   Reply With Quote
Old 09-22-2020, 04:53 AM   #4
Thank you!
Old 09-22-2020, 07:06 AM   #5
How much does the trailer weigh, and does it have brakes? If the trailer has brakes already installed, I can see no reason why you would not want to make use of them.
2020 Sunseeker 2440DS Ford, Trekker cap, Topaz paint
BehindBars is offline   Reply With Quote
Old 09-22-2020, 07:13 AM   #6
YEAH ! does that thing even have elec. brakes ? Doesn't look big enough. I haven't found anything on it yet.
TheWolfPaq82 is offline   Reply With Quote
Old 09-22-2020, 07:16 AM   #7
The trailer weighs around 1700 lbs. and has electric brakes.
Old 09-22-2020, 07:17 AM   #8
Yes it has electric brakes on it
Old 09-22-2020, 07:17 AM   #9
Found where listed standards are 7-pin plug and electric brakes. You will need a controller.
Old 09-22-2020, 07:18 AM   #10
I bought a controller and wiring ext for it. Guess I might as well use it. Can’t hurt I suppose.
Thanks everyone!
Old 09-22-2020, 07:19 AM   #11
I have an older 12' popup and weighs 2500lbs and doesn't have brakes. It's much older.
Old 09-22-2020, 07:20 AM   #12
Got a 7-pin on the truck already ?
Old 09-22-2020, 07:23 AM   #13
I have a utility trailer without any electric brakes that I've had loaded up heavier than what your trailer is and have had no issues stopping... But if I had electric brakes, I'd want to use them. They really do make a difference.
GravelRider is offline   Reply With Quote
Old 09-22-2020, 07:28 AM   #14
My 10' utility is rated at 3000lbs and has no brakes.
Old 09-22-2020, 07:41 AM   #15
I have a 12 foot utility trailer conveniently rated (just under 3000 pounds) at 2990 pounds, I assume so the manufacturer would not need to put brakes on it. It did not come with brakes, but I installed electric brakes on the trailer myself and always use a controller in the tow vehicles.
Old 09-22-2020, 08:16 AM   #16
Yes I installed the wiring harness and 7 pin connector. Woohooo.
brake control, controller
