Brake Systems and Toad Battery
Hi all,
So I've set my TOAD up with a Roadmaster Even Brake and of course it uses the Toad battery to run it's compressor and ancillary parts. I haven't done anything to charge the battery in the TOAD. In your real world experience, will it be necessary or does a brake system use a negligible amount of energy to run on a daily basis? I know there's variables, but on average, is running down the Toad battery a concern? The Even Brake manual says the unit will go into a battery saver mode, so there's that, too.
Edited to add:The Toad is a FIAT 500 so no key in the ignition and no other drain on the battery other than the normal clock and radio stuff.
TIA,
Eric
2006 Dynamax Isata IE 250
420 Ah batteries
400w Solar
