Originally Posted by bubbles
Typically, a trailer just has a lanyard that pulls out from its receptacle on the trailer closing a manual switch and the onboard battery supplies the voltage necessary to apply the brakes for breakaway. I think something like that also is utilized by those that have a toad and breakaway. I don't think breakaway is required for your toad and really doesn't need it anyway.
If you’re towing a dingy, you probably should have a breakaway switch. The EvenBrake system I use has a provision for one.
But here’s where it gets interesting. I don’t have a switch connected to the controller for the brake system now and when it powers up and performs it’s diagnostic it must sense that and just ignore it. Maybe if one was connected when the unit powers up and it senses that, pulling the lanyard or removing the switch entirely might trigger the brakes. I’ll try to test it this weekend.
