Originally Posted by moose074
I like my B&W companion, others enjoy the Anderson. If it were me I would go to my local truck accessory store that sells hitches. They might be able to steer you in right direction and being local might have an ideal of your local terrain and be able to offer more specific advice.
I second that! Get a B&W Companion hitch! Stay away from Reese (or any Horizon Global brand, DrawTite, Bulldog, etc.)! Here's what happens to you with Reese:
https://www.forestriverforums.com/fo...ml#post2352857
My Reese hitch broke loose from the truck bed and did $10K worth of damage.
You're lucky you noticed that broken part before something really bad happened. I pull a very similar 5th Wheel (2013 Puma 356QLB) into some rough areas on occasion with a 2014 Ram 3500 and after having owned two Reese hitches, I can say with certainty that the B&W is a much higher quality.
