Old 07-05-2022, 08:43 PM   #1
Camper wiring issue - Iím stumped.
I have a 2005 F250 and a 2021 FR Salem. When I picked up the camper the dealership said my truck trailer tow wiring was bad, as the right turn signal didnít work on the camper. I verified this with a 7-pin plug tester - right flasher signal was bad. Had the Ford dealership fix it. Now tests fine on the plug tester but the right camper turn signal still does not work.
I hook the truck up to my car hauler and the right turn signal DOES work. So I of course think itís just a blown bulb on the Salem. But hereís the weird part - when I hook the Salem up to my 2014 Durango - all lights work properly. 😬
What could possibly be causing this?
EVOlutionary is offline   Reply With Quote
Old 07-05-2022, 09:56 PM   #2
Got to be the Ford if it works when you hook it up to the Durango and all lights work properly.
2015 Dynamax REV 24TB class C
Reverse_snowbird is online now   Reply With Quote
Old 07-06-2022, 06:27 AM   #3
Does your car hauler have LED lights?
It could be the Ford circuit failing when put under load. If possible, I'd hook it to another trailer that has incandescent bulbs and see if it works then.
Gotta go campin!
Old 07-06-2022, 11:16 AM   #4
It does indeed. Good idea. Iíll check that out.
Old 07-06-2022, 05:25 PM   #5
Does it still work at the plug?
aircommuter is offline   Reply With Quote
Old 07-06-2022, 09:30 PM   #6
The 7-pin on the truck? I have a plug-in tester and all lights work properly on the tester.
Old 07-06-2022, 11:21 PM   #7
Sounds like the trailer load doesnít agree with the truck control module.
Old 07-07-2022, 03:52 AM   #8
multi meter will tell you if each pin is working and how much voltage it has
5 minute job ... you just need someone to operate brakes turn signals etc while you test
Tarpon Springs FL
2022 Salem 24RLXL
Aussieguy is offline   Reply With Quote
Old 07-07-2022, 08:54 AM   #9
I had the same issue with my Chevy. Turned out to be the turn signal module. Trucks of that vintage use a multi pronged module that separates the truck lights from the trailer lights. They are also fused separately. YouTube would be a great place to start to find the location and procedure on how to replace it. The turn signal switches are not like the old days. Mine was 60 bucks, and was a ten prong connector. My guess is your Ford is similar.
2003 Duramax
2017 Crusader 315
2016 Boston Whaler Montauk 150
Former Montana owner
Colorado Cruiser, Over the Pass and Down the Hill
Comanchecreek is offline   Reply With Quote
Old 07-07-2022, 04:29 PM   #10
While the meter will give information it is still controlled by the module which will shut off the feed for the load being too low or high. The module could also be defective.
Old 07-07-2022, 04:46 PM   #11
I would think if you tested the lights at the trucks 7 way with no load and got good readings then it would work hooked up with some load even leds
MR.M is offline   Reply With Quote
Old 07-07-2022, 06:08 PM   #12
Those modules have a mind of their own sometimes.
Lots of large wires going to the turn signal switch are a thing of the past and have been for a while. Three or 4 small wires send codes to the module and they do the work, sometimes the module will be controlling relays for the trailer circuits.
camper, wiring
