Originally Posted by faithie999
I am looking at buying a 2020 Ram 1500 Big Horn V-8, Crew Cab, 5'7" bed, 3.92 rear axle. I can find the comprehensive Ram towing/payload capacity charts for 2019 and 2021, but not for 2020. The only 2020 Ram towing chart I can find is for the Tradesman version.
I'm sure I will not exceed the towing capacity given the 3.92 rear axle, but I would like to know the payload capacity.
Ken
I had this same issue and called RAM several times. Got a different answer each time. All their customer service reps are contracted out. I finally got an emailed answer from them. I also had 3.92 rear axle. Here it is:
Thank you for contacting Ram.
VIN: 1C6SRFFT2LN410154 - 2020 (DT) RAM 1500 BIG HORN CREW CAB 5'7" BOX 4X4
Ram Body Builder’s Guide Towing and Hauling Information (Payload and Maximum Trailer Weight are Estimated Values)
GVWR - 7,100 lbs. (The best source for GVWR information is the Vehicle Certification Label. The label is located on the driver-side door shut-face).
Payload - 1,760 lbs. (The best source for payload information for a specific vehicle would be the Tire and Loading Information Placard. The placard is located on the driver’s side B-Pillar or the rear edge of the driver’s side door).
Base Curb Weight - 5,341 lbs. (The best way to figure out the actual curb weight of a vehicle is to weigh the vehicle on a commercial scale).
Front Base Curb Weight - 3,163 lbs.
Rear Base Curb Weight - 2,179 lbs.
Front GAWR - 3,900 lbs. (The best source for Front GAWR information is the Vehicle Certification Label. The label is located on the driver-side door shut-face).
Rear GAWR - 4,100 lbs. (The best source for Rear GAWR information is the Vehicle Certification Label. The label is located on the driver-side door shut-face).
GCWR - 17,000 lbs.
Maximum Trailer Weight - 11,220 lbs. (Class IV Receiver Hitch)
Maximum Tongue Weight - 1,275 lbs. (Class IV Receiver Hitch)
NOTE:
- Maximum trailer weight includes cargo and fluids in the trailer and must be decreased by the weight of optional equipment, upfit body modifications, trailer hitch, cargo inside/outside the vehicle and passengers.
- If the gross trailer weight is 5,000 lbs or more, it is recommended to use a weight-distributing hitch to ensure stable handling of your vehicle.
- Trailer brakes are recommended for trailers over 1,000 lbs and required for trailers in excess of 2,000 lbs.
- The GVWR, Payload, GAWRs, GCWR, Maximum Trailer Weight and Maximum Tongue Weight should never be exceeded.
- Values determined using base model vehicle and SAE J2807 standards.
- The payload and maximum trailer weights provided in the Ram Body Builder's Guide and Towing Guide are estimated values. The actual values may be less depending on how the vehicle was equipped (more options add weight to the vehicle which reduces payload and maximum trailer weight).
- Payload - The amount of weight that will be carried by a truck including the driver, passengers, cargo, tongue or king pin weight, options (factory-, dealer-, or customer-installed) and the weight of any upfit body modifications.
Sincerely,
Joe
