Originally Posted by NMWildcat
Most decent blue tooth/wifi/laptop connected readers (that can cost under $30) also give you an explanation of the code in standard English via an app. Some apps are more refined than others. I use one that also gives me real time performance charts and gauges as I go down the road. All for $40. Definitely gives you a place to start and has lots of options. If it is not enough, by all means pay someone with a professional scanner to diagnose, or spend the big bucks on a high end scanner/software.
That's still a toy. A serious tool will let you control devices on the CAN bus as well as reading their status.
For example, an Exhaust Gas Recirculation (EGR) valve has four wires. Two to command it to a state and two to read the state. If the technician (they're not mechanics any more) suspects the EGR is sticking, he can command it to go to 1/4, 1/3, 1/2, 3/4, full open states and see whether it follows in each case. You can't do that with "Torque PRO."
If you have an occasional miss, a serious tool can watch temperature and timing, and detect, for example, where a misfire due to a bad plug wire physically moved the engine enough to trigger the anti-knock sensor. The Powertrain Control Module (PCM, sometimes called the Engine Control Module-ECM), saw the knock-sensor and retarded the timing, which naturally caused the temperature to rise. It never set a P06xx misfire code which would have identified the problem. The tech I was working with saw the knock sensor message and the timing retard message and identified the problem. All I could see from the dash was the transient temperature rise after each event and I could feel the misfire. You can't do this with Torque PRO either.
Another missing feature is the ability to read Body (B) and Chassis (C) codes as well as Powertrain (P) codes. This has saved me a lot of work at least once, identifying the exact spot of the leak in a GMC Level-Ride (air-lift) system.
By the way, I'm not an auto tech. I do all my own work, but the examples above were done in cooperation with a local shop that has a policy of reading codes/doing diagnosis for free. I've tried to pay them but they won't accept it. Even the 10-minute ride to diagnose the bad plug wire.
Larry
