Change in Wear Patterns on E2 Hitch Sway Control Bars
As I was hitching up today, I noticed a change in the wear patterns where the sway control bars hit the hold down brackets. See photos. The wear used to be relatively even on the lower brackets, but now it is definitely biased toward the front (see the newly shiny areas indicated by the red arrow). Nothing has changed in my setup, at least I don't think so, but what does that change in wear pattern suggest?
I'd appreciate any ideas, thanks.
Tom
Rockwood Mini-Lite 2509S
Toyota Tundra 4WD
