Old 05-05-2020, 01:26 PM   #1
Smile Check my setup
Had my 22FBS out for the first time since purchasing it and took it the CAT scales for an idea on the setup of the Anderson weight distribution hitch. The first set of numbers is just the truck and the second set of numbers is truck and camper.
Steer Axle = 4060
Drive Axle = 2860
Gross weight = 6920
Steer Axle = 3840
Drive Axle = 3880
Trailer Axle = 5500
Gross Weight = 13220
If my calculations are correct, it appears I have unloaded the front axle by 220 lbs and I have approximately 1020 lbs of tongue weight.
Let me know what you think. Do I need to make adjustments or do the numbers look good. Thank you.
Randy & Sherry
Pensacola, Fl
Retired United States Navy
Retired Law Enforcement
TT 2020 Flagstaff 22FBS
TV 2007 Dodge RAM 2500 (aka Big Red)
woolfski is offline   Reply With Quote
Old 05-05-2020, 01:58 PM   #2
I would tighten the weight distribution bars until the front has at least the same weight loaded as it does empty and I prefer to put a little extra up there. It helps with handling and with the ride.
2020 Coachmen Mirada Select 37RB
2019 Ford Mustang
H&H Aluminum Car Hauler
Cricket RX5 Golf(?) cart
DougW is online now   Reply With Quote
Old 05-05-2020, 02:53 PM   #3
Towing Planner.com
Actual Weights - Travel Trailer/Bumper Pull Weights from CAT Scales - TowingPlanner
For your weights.
2016 Ram 2500 CTD 4x4 Big Horn
2017 Coachmen FE 292bhds
Off Rez is offline   Reply With Quote
Old 05-05-2020, 06:20 PM   #4
Check my setup
You have 800 lbs of TW plus a small amount of weight transferred to the trailer which you can't calculate from the numbers you provided. The Andersen is not known for providing much in weight distribution. Good sway control, but not good at returning front axle weight. I would say you are fine though. People have had issues trying to tighten the Andersen too much. Losing 220 is not a big deal IMO. Pickups are designed to have a load in the bed.
2011 Flagstaff 831FKBSS
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 05-06-2020, 09:49 AM   #5
Lins's Avatar
I wouldn’t worry about the 220 lbs in the front unless you have porpoising or handling issues. But with such a small trailer towed by a 2500 I doubt that’ll be an issue.
2007 Rockwood 2701SS
1953 GMC 9314
1982 GoldWing Interstate
Lins is offline   Reply With Quote
check
